Script Carving
Script Carving
Postby ken whiklo » Fri Sep 13, 2019 10:13 pm
I have been unsuccessful in carving anything other than larger signs in script. The sign I tried to carve now is 8" W x 3.5 H.
No matter what I try. Different speeds, feeds, depths the sign comes out "hairy" if you know what I mean. Tried various 60' bits, different material from plywood to solid. Doesn't matter. I have been successful in carving a larger sign with 1/8" end mill but when you shrink the sign down the gaps are too small for the tool. It appears that the v bit tears the surface on first pass and yes the bits are sharp. First one I used was brand new.
Any suggestions would be helpful.
ken whiklo
Model of CNC Machine: CWI Professor 2.2
Re: Script Carving
Postby ger21 » Fri Sep 13, 2019 10:24 pm
You need to specify the exact bits you are using, and the exact type of wood, and a picture would also help.
There are lots of different woods, and some carve much better than others.
ger21
Re: Script Carving
Postby scottp55 » Fri Sep 13, 2019 10:36 pm
The .crv file itself would probably yield the most results.
GMH
scottp55
Re: Script Carving
Postby ken whiklo » Sat Sep 14, 2019 12:56 am
I have tried thin plywood not sure of the wood, I assume spruce. Veneer maple plywood. Poplar.
Maybe I am trying to do something impossible. I was able to cut this out fairly good with a 1/16" endmill using profile toolpath.
Amelia.crv
(345 KiB) Downloaded 22 times
ken whiklo
Re: Script Carving
Postby ger21 » Sat Sep 14, 2019 1:46 am
Spruce and poplar are both soft woods, which can be fuzzy when cut. And plywood often have poplar or other softwood cores, so you can get the same issues.
ger21
