VCarve 10 Pro - 3D Modeling - Clipping - Display Results
Postby AcBCDN » Fri Sep 13, 2019 7:59 pm
I just installed the upgrade and jumped into the Clipping option in 3D Modelling. It worked great!
However, in my test example I decided to change the vector to a different one.
- I removed clipping from the level.
- Selected the new vector
- Enabling clipping again
- The visible result was still using the old vector
So, I saved the model. close the file, then reloaded it. The clipping result is now as expected; it is using the new vector.
No sure if this is a desired affect.
Andy
AcBCDN
Model of CNC Machine: HomeBuilt
Re: VCarve 10 Pro - 3D Modeling - Clipping - Display Results
Postby AdamJ » Fri Sep 13, 2019 9:40 pm
Hi Andy,
You shouldn't need to reopen the file to reset the clipping. My suspicion would be that just moving one of the models around would force a reset. I'll try to reproduce your issue. Thanks for the report.
Adam
AdamJ
Model of CNC Machine: None
Postby scottp55 » Sun Sep 15, 2019 3:46 pm
Is there a VCP10 tutorial (or Tips and Tricks) that goes into the clipping mode in a more detailed, or step by step instruction?
GMH
scottp55
