Pocket project on 3D or not?
Postby Aussie » Mon Sep 09, 2019 7:38 am
Hi All,
I have the lid for a box and I am using walnut for the base of the lid and canarywood for the 3D moon.
I wish to inlay a 3D model of a wolf, question is when cutting the pocket for the wolf do I select project on to 3D in the pocket toolpath or not ?
Ron
Aussie
Model of CNC Machine: Axiom AR6 Pro
Re: Pocket project on 3D or not?
Postby dealguy11 » Mon Sep 09, 2019 12:14 pm
No. If you project the pocket on the 3d model, the bottom of the pocket will not be smooth, so you will have difficulty gluing in the inlay.
Steve Godding
dealguy11
Postby Aussie » Tue Sep 10, 2019 1:06 am
dealguy11 wrote:No. If you project the pocket on the 3d model, the bottom of the pocket will not be smooth, so you will have difficulty gluing in the inlay.
Thank you
Will try this on the weekend and see how it goes.
Aussie
Postby martin54 » Tue Sep 10, 2019 12:04 pm
This may take a bit of playing about with or hand finishing once cut depending on the high & low points of each model. I would probably cut the wolf model first as I generally do with all inlays, it's easier to alter the size of the female pocket if the parts don't fit tgether first time because you can just check the fit with the part still on the machine & make alterations to suit. Cut the felame first & then you are down to trying to bench fit the parts :lol: :lol:
As well as the actual size of the pocket you may have to play around a bit with the depth of the pocket a bit to ensure the best look, also easier done by altering the depth of the female pocket. Look forward to seeing the finished project :lol: :lol:
Postby TReischl » Tue Sep 10, 2019 1:26 pm
If you do a bit of figuring you can cut the pocket and install the inlay BEFORE you do the 3D cutting. Some simple sketches help with that.
Postby CharlieP » Wed Sep 11, 2019 11:01 am
You may wish to consider this example project to setup your material before cutting your 3D Toolpaths.
https://www.vectric.com/vectric-communi ... =1&items=0
If you create your Inlay material and then 3D Carve it afterwards as TReischl mentions, this might give you the result you are looking for and keep the inlaying process more simple overall.
CharlieP
Vectric Staff
Model of CNC Machine: N/A
Users browsing this forum: Jim_Nestor and 5 guests
