Cutting a 3D Shape Vcarve Pro 9.5-Need Help
Postby Cncmachine2 » Sat Sep 07, 2019 6:24 pm
Cutting a two sided 3D shape using vector boundary selected. The model has holes within the outside vector selected which I do not want to 3D rough cut. Is there a way to stop from cutting the holes ? I would like to cut holes using a 2D profile cut in a separate procedure.
Thank you!
Cncmachine2
Model of CNC Machine: Mach3
Re: Cutting a 3D Shape Vcarve Pro 9.5-Need Help
Postby Adrian » Sat Sep 07, 2019 6:28 pm
Create a vector around the holes and select those at the same time as the boundary vector. Create the toolpaths with selected vectors option and it won't machine inside those vectors.
Postby Cncmachine2 » Sat Sep 07, 2019 7:08 pm
Thank you for your response. I tried your suggestion and it still cut the holes.
Cncmachine2
Postby Adrian » Sat Sep 07, 2019 7:15 pm
It shouldn't do. Hold down the shift key, click on the outside vector and then each of the vectors around the holes. All the vectors should now be highlighted. Create the roughing or finishing toolpath making sure that you have Selected Vector(s) set. Just tested it again and it definitely only machines the areas between the vectors.
Postby Cncmachine2 » Sat Sep 07, 2019 8:34 pm
Thank you again, it worked.
Cncmachine2
Users browsing this forum: BryanH, Google [Bot] and 34 guests
