COMING SOON - VCARVE VERSION 10
Postby Stephanie Downing » Fri Sep 06, 2019 3:45 pm
We're thrilled to give you a sneak peek into some of the NEW and improved features coming up very soon in version 10 :D
NODE EDITING ENHANCEMENTS
Version 10 adds the ability for node editing to be performed on multiple vectors at the same time as well as allowing you to transform vectors directly from the span itself by dragging individual spans to change their shape in the case of arcs and Beziers.
Where you have two open vectors, you can select the end points of each vector and join them together whilst remaining in node edit mode using the right click menu, join them with a straight line, a curve or the mid point between the two.
WELDING TEXT
The welding tool includes the welding of text objects all at the click of a button! Which is perfect for overlapping style fonts.
Simply select your text, use the weld option where it will keep all of the internal regions of the text characters. You also have the option to keep or replace the original text object.
TOOL DATABASE OVERHAUL
Do you use the same tool, but want different speeds and feeds for different materials? You can now adjust the parameters based on the material you're using. Once your materials are set up and you are ready to machine, you can filter the tools so that you only see the ones that are compatible with the material you're using.
Use the new tool naming mechanism to consistently name your tools. Ensuring that the tool name always matches the tool dimensions. It even supports displaying inch tools correctly.
LEVEL CLIPPING
Makes it easy to constrain the model you are creating to a chosen boundary. Rearrange your components and see the results of clipping live as you work.
Watch out for more announcements of version 10 updates coming soon!!
Stephanie Downing
Vectric Staff
Model of CNC Machine: xxx
Re: COMING SOON - VCARVE VERSION 10
Postby kstrauss » Fri Sep 06, 2019 8:28 pm
Will v10.0 be a free upgrade from v9.5?
kstrauss
Model of CNC Machine: Tormach PCNC770
Postby AdamJ » Fri Sep 06, 2019 9:35 pm
Hi kstrauss,
That would depend on when you purchased your version of 9.5. V10 is a free upgrade for anyone who has newly purchased the software within 12 months of the release date and to anyone who has upgraded their software within 3 months of the release. If you are entitled to a free upgrade then you will be credited with the new version and it will appear in your V&CO account. You will also be notified via email at the point of release, so you won't be left in the dark :)
Cheers,
Adam
AdamJ
Model of CNC Machine: None
Postby Mark Bolton » Sat Sep 07, 2019 4:22 pm
Well hopefully you get it out in the next week. Perfect timing. We upgraded on Jun18th so get crackin'.
Mark Bolton
Model of CNC Machine: ShopSabre408PRO-10HPHSD-10posATC-WinCNC
Users browsing this forum: martin54 and 24 guests
