Error codes
Error codes
Postby tmoore4049 » Sat Aug 24, 2019 10:11 pm
I'm getting the error attached below. I see no reason this should be happening. Any ideas. I'm profile cutting .25 slots with .25 bit. Numerous other matching
profiles in file. I'm confused :cry:
tmoore4049
Model of CNC Machine: Camaster Stinger III
Re: Error codes
Postby IslaWW » Sat Aug 24, 2019 10:29 pm
Set the bit diameter to .248
Gary Campbell
CNC Technology & Training
GCnC411 (at) gmail.com
IslaWW
Re: Error codes
Postby tmoore4049 » Sat Aug 24, 2019 11:00 pm
Thanks Gary. I actually reduced it to .235 and still getting same message. I have 18 similar vectors on same file and this is the only one getting me. See attached
paddle board ribs
tmoore4049
Re: Error codes
Postby mtylerfl » Sat Aug 24, 2019 11:03 pm
Likely “bad” vectors. Use the Vector Validator tool to see where the problem is and then make corrections. Also check for open vectors.
Re: Error codes
Postby tmoore4049 » Sat Aug 24, 2019 11:08 pm
I did that too. Showing no problems????
tmoore4049
Re: Error codes
Postby mtylerfl » Sat Aug 24, 2019 11:14 pm
Ok. Post your actual Vectric file here so we can take a look at it directly.
If the file is too large, post it at your DropBox account and post the download link here. Thx
Re: Error codes
Postby tmoore4049 » Sat Aug 24, 2019 11:23 pm
Here's the file. Thank you.
PADDLEBOARD GRID.crv
Vectric file
(303.5 KiB) Downloaded 18 times
tmoore4049
Re: Error codes
Postby tmoore4049 » Sat Aug 24, 2019 11:30 pm
Profiling exterior one to the right is the one..
tmoore4049
Re: Error codes
Postby mtylerfl » Sat Aug 24, 2019 11:30 pm
tmoore4049 wrote:Here's the file. Thank you.
Change your stepover to 1%, recalc, then see if that works for you. Oh, and you can enter the diameter of the bit as 0.25", no problem.
Re: Error codes
Postby tmoore4049 » Sat Aug 24, 2019 11:33 pm
Same thing. Even dropped it to .5%. Same thing
tmoore4049
Re: Error codes
Postby mtylerfl » Sun Aug 25, 2019 12:44 am
Hmm. Are you running Desktop or Pro? What is the version number you are running?
I just tested the one you had highlighted. It worked fine. However, three of your profiles are Open vectors! Close them and you should be good to go. (I’ll try it myself in a few minutes, to confirm)
Do you know how to find open vectors yourself? Hint: It’s not by zooming in)
EDIT: I just tested all the profiles after closing the 3 open ones. Works perfectly! (see screenshot)
Re: Error codes
Postby tmoore4049 » Sun Aug 25, 2019 1:16 am
Thank you for your time. PRO 9.5. I ran vector check and it shows no intersections, overlaps or opens? At this point I guess I'm going to have to redraw outline? I'm outta ideas.
tmoore4049
Re: Error codes
Postby mtylerfl » Sun Aug 25, 2019 1:27 am
No need to redraw anything.
You find the open vectors in 5 seconds or less by going to the Edit menu, then choose Selection/Select All Open Vectors
Now you’ll see the 3 open profiles selected. Now you can select them one at a time and click the “Join/Close - vectors by moving end points to common point” icon. (Note: pressing “J” on the keyboard will join a couple of those but not the third one. In case anybody was wondering!)
After that, you should be able to calculate your profile cuts with no problem. Holler if you still can't do it yourself. I'll post the corrected file if needed.
Re: Error codes
Postby tmoore4049 » Sun Aug 25, 2019 2:18 am
Awesome. Thank you Michael.
tmoore4049
Re: Error codes
Postby tmoore4049 » Sun Aug 25, 2019 2:20 am
Worked perfectly. You rock!
tmoore4049
Next
Users browsing this forum: No registered users and 43 guests
