Job Sheet doesn't show design
Postby BEF » Mon Aug 19, 2019 11:09 pm
A newbie here... I made a design for a tray for my bits; all good. But when I print the job sheet, it doesn't show the design in "Job Layout." What am I missing???
I'm attaching the .crv file and a pdf of the job sheet.
Thanks, everyone!
Bit Tray V2.crv
(1.45 MiB) Downloaded 34 times
Screen_Shot_Job_Sheet.pdf
(314.03 KiB) Downloaded 28 times
BEF
Model of CNC Machine: Axiom AR6 Pro+
Re: Job Sheet doesn't show design
Postby highpockets » Mon Aug 19, 2019 11:36 pm
Not sure, works fine for me.
Postby gkas » Mon Aug 19, 2019 11:39 pm
There are tiny objects off in the FAR lower right. They're off your drawing. Delete them and all is well.
gkas
Postby BEF » Tue Aug 20, 2019 4:38 am
Thanks, GKAS, you were right "on the money." Not sure how they got there, but that did the trick. I'll know to look for that in the future. Thanks for helping a newcomer!
BEF
Postby gkas » Tue Aug 20, 2019 6:10 am
No problem, we've all been there. I think the mistake is made by drawing by accident while in a 'draw' mode. Accidental mouse clicks.
gkas
Postby BEF » Tue Aug 20, 2019 3:34 pm
Your sympathy is appreciated! Quite a learning curve on this all. Thanks again.
BTW: We are both Axiom owners - I just got an AR 6 Pro+ as my first CNC.
BEF
Postby gkas » Tue Aug 20, 2019 9:59 pm
There is an Axiom forum at http://axiomprecision.proboards.com/
gkas
Postby BEF » Wed Aug 21, 2019 4:41 am
Thanks. I knew about that.
Also noted that you have the Axiom Laser. I've just got it mounted and am looking for good test projects. Any suggestions?
BEF
Postby gkas » Wed Aug 21, 2019 6:35 am
I ran a series of small squares, and sets of lettering to test. Each done 20 ipm, 40 ipm, 60 ipm 80 ipm and 100 ipm. This is what I use to test a cut in new material; felt, thin board, cardboard, etc. I do the same for the engrave text. Each time I use a file, I duplicate it and I either remove the ones I think will not be in range, or dupe a range to get finer gradiations. You don't want to test cardboard at 20 ips. You can lengthen the burn times by using the 'Speed Scale Adjustment' (Y+/- buttons) to decrease the ips. 100 ips is a pretty light burn. You can't increase it beyond the factor of '1'. If you decrease to 50% (0.5), then you change 100 ips to 50 ips (or pretty close).
I save these test files, and pretty soon you have a good set of test runs. You CANNOT control the intensity of the laser, only the duration using different speeds. There is a connection on the laser for an intensity, but no way to control it from the Axiom.
I cut felt liners, game pieces, tiny wood pieces, and some logos. I do engrave my signature in the backs of some of my pieces.
gkas
Users browsing this forum: Adrian, ger21, kaetamer, scotttarnor and 44 guests
