Faster/better/template suggestion for common project steps
Postby MSchienle » Sat Aug 17, 2019 12:42 pm
Hi all -
I'm looking for a better way to create/import barrel hinges in a variety of boxes. Hobby woodworker here (software engineer by day), working with VCarve Pro (9.518) for 6 months now. CNC is Next Wave Automation's little Piranha Fx.
I'm using Soss 1/2" hinges, which use a 0.415" diameter hole, 0.48" deep, offset from the edge of the box 0.072" for clearance when opening. I use a pair of concentric circles, one for the hole itself, one for the offset to the edge of the box (I use a circle for the offset since about 1/2 the boxes are non-square) to lay it out each time. I use a pocket toolpath with a 1/4" end mill, clearing the pocket with offset and climb settings.
It's not a big deal to set those up for each box, but I would like to know if there's a simpler way to template this so the circles can be grouped/aligned and a toolpath would be already in place with a drag and drop or keystroke or three. I typically copy/paste from a previous project, but have a feeling there's a better way for repetitive things like this that I haven't discovered, yet. I've watched all the VCarve videos, but I may have missed something I wasn't ready to understand along the way.
Mike Schienle
Piranha Fx
MSchienle
Model of CNC Machine: Piranha Fx
Re: Faster/better/template suggestion for common project ste
Postby Adrian » Sat Aug 17, 2019 12:57 pm
Drag and dropping the geometry is the way I do similar type jobs. The step you might be missing is the use of toolpath templates so you can have toolpaths automatically associated with those vectors. Creating/updating the toolpaths is just a matter of clicking the recalculate all button.
The way to make it totally automated is to write a gadget. I have many simple ones that I use for repetitive tasks.
Postby MSchienle » Sat Aug 17, 2019 1:14 pm
Thanks, Adrian. I'll check out toolpath templates and gadgets.
Mike Schienle
Piranha Fx
MSchienle
Users browsing this forum: No registered users and 24 guests
