pocket hole problem
pocket hole problem
Postby gareth52 » Fri Aug 09, 2019 2:04 pm
Hi, I have been testing cutting rebates in ply and the results I’m getting are bemusing Can anyone please explain the differences I am getting in size. I am using the pocketing function in V carve. In this program there are 3 possible settings for the profile cut (1st, last, none). I was getting a ragged edge when using the default setting of last. So I tried setting the profile cut to 1st. Whilst it was a clean cut, the pocket was wider than the pocket cut with the profile at the end. I have listed various details below: –
PROFILE CUT LAST (inch)
0.432
0.438
0.444
PROFILE CUT 1st (inch)
0.485
0.489
0.492
Is there a reason for this?
Cheers,
Gareth
gareth52
Model of CNC Machine: 3 axis home built cnc machine
Re: pocket hole problem
Postby TReischl » Fri Aug 09, 2019 4:40 pm
Where are those numbers coming from?
If those are measurements you took then I would venture that your bit is deflecting.
Another couple of questions:
What size bit are you using to do that cut?
How far out of the collet is it hanging?
The real answer to your question is in the gcode. I would bet dollars to donuts that the machine is being commanded to the exact same locations in both strategies. Hint: We have all been cutting pockets for years and years, so think like tens of thousands of pockets having been cut. If this were a software issue we would have all been talking about it long ago.
Postby ger21 » Fri Aug 09, 2019 6:22 pm
My guess would be machine deflection.
ger21
Postby gareth52 » Fri Aug 09, 2019 6:48 pm
Thanks for your replies. I measured the pockets with a pair of digital calipers. Like you, I’ve cut hundreds pockets, but I’ve never used the profile cut 1st option before. I’m using a 3 mm bit and it protrudes from the collet about three quarters of an inch.
Since you have both offered the possibility of deflection, I will try again using a shorter bit.
thanks again
gareth52
Postby Adrian » Fri Aug 09, 2019 7:44 pm
Thing to bear in mind is that if you're using the profile 1st option then there will be more load on the bit (more likelihood of deflection) as there is material on both sides of it. Cutting the profile last means less load because the "inside" material has already been removed.
Postby TReischl » Fri Aug 09, 2019 8:07 pm
Adrian wrote:Thing to bear in mind is that if you're using the profile 1st option then there will be more load on the bit (more likelihood of deflection) as there is material on both sides of it. Cutting the profile last means less load because the "inside" material has already been removed.
Hmmmm, Adrian. . . . There may be less load on the last pass option, but that load is all on one side with nothing on the opposite side to resist it. Obviously more of a problem with smaller bits.
Postby gareth52 » Sat Aug 10, 2019 10:08 am
After thinking about the 1st 2 answers last night, I had also thought that there was more chance of deflection using the profile can’t last option. This would force the bit inwards, creating a smaller pocket.
I’ll try again next week using a shorter bit and also a 0.25-inch bit.
gareth52
Postby sharkcutup » Sat Aug 10, 2019 1:31 pm
Maybe feedrate being too fast causing unnecessary deflection!
Just an additional Thought!
Sharkcutup
Facebook: Hogan's CNC Crafts
Website: www.hoganscnccrafts.com
V-Carve Pro 9.518
sharkcutup
Postby TReischl » Sat Aug 10, 2019 1:48 pm
I'll try not to go into a long winded dissertation here but. . .
Sometimes I need to cut quite deep with a very small endmill, think .5 deep with a 1.5mm (.059) end mill to get good detail and crisp edges. I have found that if I make that cut after clearing out material I have all sorts of problems, deflection, bit breakage, etc. What does work is to make those cuts first. I use bits that have a very high spiral that helps pull the chips out and prevent packing. Also make sure the dust collector is running for the same reason. At the same time that technique helps prevent chipout at the surface by larger bits.
Postby gareth52 » Fri Aug 16, 2019 3:07 pm
After some experimentation, I finally determined that using a shorter bit length, making the profile cut 1st and slowing the feed rate down to 50 in/min was the best way to go on my machine. It produced much better repeatable results.
Thanks for the help and advice you gave me.
gareth52
Users browsing this forum: Inchlaggan, Jan.vanderlinden, Lesa Duncan, mark-s and 49 guests
