Can't delete lines
Can't delete lines
Postby raye321 » Fri Aug 02, 2019 12:19 am
Hi, I did a project on vpro 9.0 There are lines that form a very small rectangle that I can't delete. It is so small, I didnt notice it until I ran the project and the 1/8" bit I was using made a mark on the wood. Anyone know How to delete it?
raye321
Model of CNC Machine: Digital Carver
Re: Can't delete lines
Postby martin54 » Fri Aug 02, 2019 12:25 am
If you zoom right in it should make it large enough to select, if that doesn't work can you box select it? If you can't then it might be because it is grouped with something else You could try moving other parts to a different layer until it is isolated & then delete that layer but remember not to trannsfer the vectors to another layer :lol: :lol:
Postby raye321 » Fri Aug 02, 2019 5:34 pm
I can't box select it either. I'll give it a try.
raye321
Postby mtylerfl » Fri Aug 02, 2019 5:37 pm
Hi Ray,
Can you post your file here? I’m sure we can help you instantly if we see the file.
(Could be a “Locked Layer”, but won’t know until you post your file or you check that yourself.)
Postby martin54 » Fri Aug 02, 2019 8:02 pm
Like Michael says if the file isn't copyright then posting it here will help experts like him sort the problem for you, if the part you can't delete is grouped with other items then that will prevent you box selecting it, maybe try ungrouping everything before trying to select it. :lol: :lol:
if you can't post the file then consider sending it to vectric support to help. :lol: :lol:
Postby sharkcutup » Sat Aug 03, 2019 8:32 pm
Sounds to me like there is a LOCKED layer in which the tiny square is attached to OR the tiny square is part of a GROUP of vectors!
Can you post your file here for review provided there is no copyright material included with the file???
Sharkcutup
Facebook: Hogan's CNC Crafts
Website: www.hoganscnccrafts.com
V-Carve Pro 9.518
sharkcutup
Users browsing this forum: No registered users and 26 guests
