Help!!
Help!!
Postby Bumps » Fri Jul 26, 2019 11:26 am
HELP!!
I have a problem that I can't work out.
I run with VCarve Pro and Shapeoko XL. When I load a new program the cutter moves to the XYZ position but then does nothing although the computer shows that it is moving through the program!
If I load an old file it cuts it no problem! I think it might be a programming problem although really I have not got a clue. Is anyone able to help?
Bumps
Model of CNC Machine: Shapeoko XL
Re: Help!!
Postby Adrian » Fri Jul 26, 2019 11:34 am
Have you selected a different post processor (when you save the toolpaths from VCarve) by mistake or changed it?
Re: Help!!
Postby Bumps » Fri Jul 26, 2019 4:11 pm
No, it is just the same as always, I have gone through everything got me completely baffled.
Bumps
Re: Help!!
Postby Adrian » Fri Jul 26, 2019 5:13 pm
Does your machine transfer the code via an SD card? Might be worth trying a different one if so. There have been people with similar issues in the past here that did that and it worked again.
Re: Help!!
Postby Bumps » Fri Jul 26, 2019 9:30 pm
Hi Adrian
You were right.
I do most of my work on my computer in the house then download to a stick and take it to the computer in my workshop. I recently load VCarve Pro onto my computer in my workshop. I checked my main computer and the post-processor was correct. but when I checked my workshop one it was wrong! I have changed it and now everything is back to normal.
Thanks for bringing my attention to it.
Bumps
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 32 guests
