importing text into texture VCP9
Postby jgstang » Sun Jul 21, 2019 9:58 pm
Right when I think I have it nope.. is there an easy way to have raised text into texture surface ? JUST CAN'T FIGURE IT OUT! the texture just over takes the whole thing.. also if you don't mind, fitting the texture with'in a frame/border thanks
jgstang
Model of CNC Machine: iconic 2015
Re: importing text into texture VCP9
Postby Adrian » Sun Jul 21, 2019 10:24 pm
Depends how you're doing it. If you're using the texture toolpath you need to have the outer vector and inner text selected when creating the toolpath so it knows to avoid the text.
Not sure on the process for 3D texture as I don't use those as they take so long compared to the toolpathed versions.
Postby jgstang » Sun Jul 21, 2019 10:51 pm
don't use 3D, I like the simple toolpaths to! it would be nice to be able to get it done all the same process but.. maybe i'll be better off just do my toolpath and then just use my router for the texture ? right now i'm just selecting texture and it does the whole damn thing.. so i'm doing something wrong! probably easy once you learn it, but sure looks like its going to take time to learn it though.
jgstang
Postby SteveNelson46 » Sun Jul 21, 2019 10:51 pm
If this is what you are looking for, use the create shape tool to create a text component on the texture and set it to to "Merge". Then play with the shape heights and base heights.
EDIT: I just saw that you only have V-Carve so you will not be able to create a component.
SteveNelson46
Postby mtylerfl » Mon Jul 22, 2019 1:18 am
This VCarve Video Tutorial should be helpful for what you are doing:
https://support.vectric.com/tutorials/V ... ideo_id=11
Postby martin54 » Mon Jul 22, 2019 12:03 pm
If you read Adrians post then he has told you how to do it, just follow what he has said when creating the texture toolpath, not difficult to learn at all, just a case of selecting the correct vectors.
Postby jgstang » Tue Jul 23, 2019 12:36 am
Wow... I did it! still fine tuning but I did this one with the texture, so this one has pocket and texture toolpaths.. I save them separately right and it will be 2 carves ? thanks
jgstang
Postby jgstang » Tue Jul 23, 2019 12:43 am
jgstang
Users browsing this forum: ger21, Google [Bot], rlp17820 and 29 guests
