I often need to engrave raised letters on a 3D surface. Vcarve seems to do the job but when i simulate the toolpaths with Cut depth set to 0 1 mm i´m can not see the material removal. How to solve this issue ?
I only see material removal when the the Cut depth is set to 1.0 mm but doing this i´m cutting bellow the surface i´ve imported. Is there a way to impose a clearence on a 3D toolpath ?
My steps were ;
1- Import stl 3d model . The imported surface is where i need to palce the raised letters.
2-Create 2d vectors
3- Create toolpath and project them on the 3d surface.
4- Simulate , but i do not see material removal.
Regards,
M Dias
