Single Line fonts
Re: Single Line fonts
They are made up of single lines so have no stroke thickness, it does not mean that they are just one single line though
Not great at explaining things like this but found this which may help.
Conventional fonts utilize two lines, an inner and outer pair of lines, that define the shape and thickness of the letterforms. One line fonts have no defined thickness, only a single line path for a pen, laser, or milling tool to follow for efficient & clean looking text.
- Aussie
- Model of CNC Machine: Robotics Model 8
Thank you Martin.martin54 wrote:They are made up of single lines so have no stroke thickness, it does not mean that they are just one single line though
When I did a profile cut 1mm depth "on the line" using a 90 deg 1/2 inch bit... it produced a small ridge in the centre of the letters..... did I use the wrong settings ?
Ron
Crafers Crafts
Crafers Crafts
