Moulding Toolpath Plunge
Postby gkas » Wed Jul 17, 2019 12:39 am
I created a simple toolpath to cut Scrabble tile racks. Simple and straight forward. I'm cutting it into 3/4" material, testing on some pine, later hardwood.
My question is concerning the plunge on the front and rear of the rack. It basically goes to the thickness of front and back at full plunge. With a 0.25 BN in pine, it's no problem, but could be with hardwood. From perusing the HELP file, it looks like the only way to control this is to use a Larger Area Clearance tool. This means two passes on the material, clearance and finish. Is my assumption correct. Is there a way to force the single pass, but using the defined pass depth?
tnx,
Gerry
gkas
Re: Moulding Toolpath Plunge
Postby 4DThinker » Wed Jul 17, 2019 1:37 am
I would eliminate the vertical side, and make the starting point at the top of the curve. Then as the moulding pass progresses it will step down into the wood rather than do a deep plunge. For the vertical side I would just use a profile toolpath.
4D
4DThinker
Postby gkas » Wed Jul 17, 2019 3:13 am
That worked out nicely..... tnx
gkas
Users browsing this forum: Google [Bot], Mike Fuson and 26 guests
