Snack Bowl Project
Re: Snack Bowl Project
Postby SteveNelson46 » Mon Jul 15, 2019 1:21 am
martin54 wrote:Martin:
It wouldn't upload for me either so I just posted a shared link. I think the file is too big for the forum limit.
Yes file limit would be the problem, I was in a bit of a hurry as I was going out, never stopped to think that it was a link you posted & not the actual file, I blame it on old age :oops: :oops:
Martin,
Me too. I had to try it twice before I realized it was over the limit.
SteveNelson46
Postby cusoak » Mon Jul 15, 2019 11:46 am
I just downloaded the second file post and does come up fine the profile of all of the bits are there.
When I click on one of the bits it turns red. So I assume that I copy and paste to a new file and the select the right half and use that to create the new tool in the tool file.?
Now back to the right bit to buy.
It will need to be larger that the collett in dia. correct?.
If I am going to cut to a depth 1.5" will I need a bit with a longer shank so that it will cut deep enough so that the router does not bottom out on the top of the material?
Jeff
cusoak
Postby cusoak » Mon Jul 15, 2019 11:53 am
Steve in the box that you posted here what brand and model number did you use of box core bit to cut the pockets.
Thanks Jeff
cusoak
Postby SteveNelson46 » Mon Jul 15, 2019 4:11 pm
There is nothing special about a core box bit. Sometimes it's even called a bull nose bit so any core box bit from any source will work. I think the one I used came from Woodcraft. Even bits from Home Depot are okay. However, quality may be an issue.
To create the bit from the bit profiles file you don't need to cut and paste to a new file. Just zoom in close, cut the vector at the mid point and use the right half. Don't save when you close the file. Be sure to check the size against the actual bit for accuracy.
SteveNelson46
Postby SteveNelson46 » Mon Jul 15, 2019 4:36 pm
Another way to create a bit profile is to take a picture of the actual bit and import it into Aspire. Use the line drawing tools to trace around the perimeter then resize the vector to the actual size of the bit. Use the right half to create the bit profile in the database. Keep in mind that undercuts will not work so be sure to keep the arcs within limits For example, this will not work for a point round-over profile.
SteveNelson46
Postby cusoak » Tue Jul 16, 2019 10:54 am
Thanks for your help
Jeff
cusoak
Previous
Users browsing this forum: BessieHunter and 10 guests
