Masking terrain model?
Postby MillAlien » Tue Jul 09, 2019 5:00 pm
Not sure what to call what I want to do so ... I'll just dive in...
I imported a 3D terrain model and want to "mask" as section of it, marked in yellow on the attached thumbnail, so that it's not carved with the model's tool path. The masked area would become a pocket on a separate tool path.
I'm my simple mind, I'd draw the rectangle and push a "delete all" vectors inside the rectangle button. But ... it doesn't seem like it works that way. I can carve a deep pocket in the model using that rectangular vector, but that's too deep - the high Z on the terrain model is 3.1", the job thickness is 4" and I'd want the bottom Z on the 'masked pocket" at about 1/2".
Can anybody who gets my drift helps sort this for me?
Thanks!
MillAlien
Model of CNC Machine: Laguna Swift 4x4
Re: Masking terrain model?
Postby adze_cnc » Tue Jul 09, 2019 5:14 pm
Roughing and Finishing toolpaths: for "Machining Limit Boundary" use "Selected Vectors". The vectors are the rectangle you want to exclude and the rectangle around the terrain.
Creep, crawl, toddle, walk, run
Best answer for a simple question? Help > Help Contents
adze_cnc
Postby MillAlien » Wed Jul 10, 2019 2:59 pm
Fantastic!
Thanks for quick reply...
MillAlien
Users browsing this forum: cusoak, Google [Bot], KENYPETE and 6 guests
