Branches, Firewood, and "Found" wood
Postby scottp55 » Fri Jun 28, 2019 4:17 pm
NOT for everyone, but I LOVE free wood :)
Playing yesterday with some small Black Walnut branches from the "Scrap" pile left at my Aunt's from her big tree(almost 40" Diameter).
Yesterday's branches had unfortunately got tucked away and hidden for 2 years, AND though I had hastily sealed the end grain with an oil/wax mix, I somehow in my haste forgot to seal the branch cuts and the chainsaw cuts on the side. Bad enough I didn't get to the branches for 3 hot days after cuts....should be sealed within Minutes, NOT hours...and certainly not days!! :oops:
This branch had 2 different diameters, and the big chainsaw cut on the larger piece, didn't match how I wanted to cut the smaller piece, so table saw cut it in two, and trimmed the chainsaw end grain cuts, and then sealed.
I always cut the "Back" side of the wood after looking at it and guessing the grain. I TRY to keep the Heartwood at the same height end to end.
Also TRY to go down enough so piece will jig up solidly for the top carving. On Black Walnut I try to get into a kind of pretty pattern for the back, but usually stop before Heartwood is hit, as I can always sand a hair more off.
Yesterday's piece was kinda marginal, as Heartwood had actually split from Sapwood. Also splits had developed from the untreated branch stubs and where chainsaw actually hit the wood :oops:
BUT, very interesting pattern on the bigger piece;
And smaller Plain Vanilla piece has very predictable Heart/Sap line;
Today will be doing 2 pieces that had similarly been "lost" behind my shaper and a box somehow and ends had NOT been treated.....Must have been a dead branch on the tree, as insect damage
was noticeable,and the bark was loose. Insects in the shop was scary, so put in oven at 200F for 60 minutes, even though a firewood study by the State said Zero insects at Any stage were alive after 45 minutes at 160F by what is now State Law for incoming firewood from other states.
SO today's victims are the two wormy/split pieces being surfaced on the second side so I can see where the wormwood is, and where to trim/butterfly wedge the splits?
Also one little cut-off that WAS well sealed after trimming off sections for the 2 "Owls in a Branch" already cut, will have "Back" trimmed flat.
Kinda mindless work, but sometimes very rewarding for my small pieces...and if it's REALLY SCRAP I can chuck it in the woods and have more room:)
scottp55
Re: Branches, Firewood, and "Found" wood
Postby Leo » Fri Jun 28, 2019 4:21 pm
Not so mindless.
Cool post and cool thoughts on the wood and what you go with it.
I am certain it WILL become something even more cool in the future.
www.leosworkshop.com
Leo
Postby scottp55 » Fri Jun 28, 2019 4:34 pm
Shush Leo...I'm Playing :)
Just came back in to edit, as I forgot the State's temp/duration now required.
Anybody else's pic's are ENTIRELY welcome!!
Hard to have too MANY ideas floating around:)
Oh, a couple pics of stuff done on this "Scrap" already that you've probably already seen.
scottp55
Postby scottp55 » Fri Jun 28, 2019 10:06 pm
DON'T like Wormy Wood!
But may be able to use it someplace.
In Opal, sometimes the pattern of color in the rock looks like Ideograms, and are called "Chinese Writing Stones" and sometime command a High value....
I Kept HOPING to get a pattern, or Einstein's Theory, or even a simple "Hello Earthling"...but no such luck :wink:
After going all through that and trying to find a method....I felt LUCKY to wind up with 2 similar shaped lines, and then vertical holes that could be filled with a carved stone or contrasting sawdust/CA.
Anyways, at least I added to my stash of Walnut on the couch, and it's not dusty and tucked away in the shop where it's hidden!
Kinda liking that one highly figure one that if you squint REAL hard, and pretend it's a Rorschach test....look kinda/sort like a wolf :D
All told, I cut about a total of 4.5" off the ends to eliminate the end checking.
House smells like beeswax and oranges...which is good, because with DC going shop hit 85F.
Lot of bark and dust in my steel Dust Deputy container I imagine:)
All taken to 600G, and either oil/waxed, or resin/oil/citrus thinner mix.......oil/wax is better for end grain checking prevention.
Oh...On MOST of those...I cut down to just Before(or AT) the beginning of the Heartwood for what I considered the "TOP"...so carving down into it now will give me the best figure and contrast.
Now that I have 2 parallel faces on the 2 Wormy pieces, it doesn't matter as much because it's easy to jig, and take more wood off later if needed.
scottp55
Postby scottp55 » Sun Jun 30, 2019 3:24 pm
I THINK this is the last Black Walnut branch from my Aunt's tree :)
Priorities JUST got changed yesterday for surfacing them, as my San Francisco Niece and Nephew visited for the first time in 5 years(now 15 and 10 years old).
MADE myself some more work when I offered them a Piece each....and BOTH were 3D's AND unsigned....2 stands coming up :lol:
I got one piece jigged up so Heartwood was level, and surfaced to rough depth, but then Kid's showed up and never took a pic.
scottp55
Postby phill05 » Sat Jul 06, 2019 9:20 am
Scott,
Man after my own heart I love to see your images and one I would like to see is your keyboard stand please.
Phill
phill05
Model of CNC Machine: Hybrid re-build
Postby scottp55 » Sat Jul 06, 2019 12:25 pm
Ah Phill......
The Project where on the Shopbot Forum one guy said "My Shopbot is a TOOL.....I don't make a Fu**ING ALTAR for it!!!!" :D
He' had obviously never been in a wheelchair, and had 4 teams of surgeons making a Project of his Spine for 20+ hours!! :)
This is almost a thread by itself, as I looked all KINDS of computer shelves other people had made to make their lives easier.
Have less than 5 hours before thunderstorms stop my cutting...WILL start another thread later when I get more pics from another computer from 2013-2014.
Must say that my back LOVES the roll under/move out of the way shelf, and not have to constantly turn sideways or put my brakes on/off!
But here's a couple;
Even works if you broke 2 toes that got infected, and you have to keep your foot up on an upside down monoski crutch for 6 weeks :D
scottp55
Postby phill05 » Sun Jul 07, 2019 10:43 am
Good on you mate, thanks for sharing interesting how you have the shelf set up, I too look how to make and use to make it easy for me, my spine is totally fused.
I always look out for your posts a pleasure to read.
Many thanks
Phill
phill05
Postby scottp55 » Mon Jul 08, 2019 2:45 am
Thanks Phill!
It was certainly better than my First set-up when the machine got here!!
I was bashing my feet/leaning over/and twisting 90 degrees all the time.....could only work a few hours before my back called quits, OR go on bed rest for weeks to heal my feet. :(
OH....Shelf was bolted from underneath to the slab using furniture connection bolts.
Not sure how it would have held up to abuse otherwise, as people leaning on it, and me using it as leverage to move the whole mobile unit around.
Also, having it cantilevered like that...it telegraphs and amplifies all machine vibration!!!
Actually made me a better cutter, as the vibrations of the monitor made it EASY to see when I wasn't cutting smoothly! :)
Unintended benefit....if you can't read the monitor(and your coffee is spilling)...TWEAK the cut! :D
scottp55
Postby scottp55 » Thu Jul 11, 2019 10:04 pm
Kinda quiet today, so just adding some pics of 2017 firewood I stole with permission from Libby's Camps on on of Dad's and my fly fishing excursions;
All Birdseye Maple of course..Kinda easy to notice in the pile if a piece of bark is split off.
Birdseye on the outer trunk goes straight into core all the way pretty much.
If surfaced from the bark toward core=Birdseye
If wood is split towards the core already,and you surface bark to core= streaks of the Birdseye show as streaks of highly figure wood.
Just mentioning.
scot
scottp55
Postby scottp55 » Thu Jul 11, 2019 10:06 pm
Here's how it looks if you surface bark to core presplit Birdseye;
See how the Birdseye traverses the full radius of the tree in almost a straight line? I never knew :oops:
scottp55
Users browsing this forum: calgrdnr, Google [Bot] and 30 guests
