Rounded bases of pockets.
- Model of CNC Machine: Custom built machine using UCCNC
Hi fellow CNC enthusiasts.
I have a CNC router made from 45/90 extrusion with a 2.2kw water cooled spindle. I am running UCCNC to control the machine. It is great fun.
I currently use other software for both modelling and generating toolpaths. It is a truly wonderful software and overkill for my purposes in many ways.
However it poor at engraving, doing things like vertically oriented text is annoying as you have do one letter at a time etc. Not had great luck with importing vectors either, though you can do it.
I have downloaded the demo version of V Carve desktop and have been playing with it quite a bit. It is obviously better at lettering and engraving.
It takes me less time to do simple engraving designs in vcarve.
I am considering buying it this week. But....
I cannot seem to get a rounded bottom or top to pockets.
I have a small project in mind, a block 300mm by 200mm by 45mm. In this block I wish to pocket out some holes about 35mm deep of a few different shapes to hold keys, glasses, loose change etc. In the centre will be a v carved logo and maybe a line drawing.
I want the bottom of the hole to be a smooth transition from the flat bottom to the side. (In Fusion it is called a fillet) not necessarily the same diameter as the bit. And a similar but reversed transition from the flat top to the side. I can draw it in Fusion but not in vcarve.
Now I could I suppose do the main carving in Fusion then the engraving in vcarve but I am sure can be done in vcarve .
If not I am not sure it will be worth buying or not.
Any advice much appreciated.
Ollie
Ollie
- rscrawford
- Model of CNC Machine: CAMaster Cobra 408 ATC, ShopSabre IS408
Re: Rounded bases of pockets.
There are a few ways to do this in V-carve.
Probably the easiest and the best results would be to use the moulding toolpath. There are videos of this in the tutorials.
Russell Crawford
Thanks rscrawford.
I will give it a go. It is tricky learning a different approach to get a similar result.
To me it is like in the other software you fully create the model before working on the CAM part. But in vcarve the drawing and CAM are sort of done at the same time.
I will have another go using the moulding toolpath.
Cheers
Ollie
Cheers
Ollie
The Pro version supports gadgets, and the FlutePlus gadget lets you design any Z profile on a series of X-Y vectors to make bowls, dished pockets, etc.
Paul Rowntree
- sharkcutup
When I want rounded edge pockets at the bottom I have used High Core Box Bits .375" dia & .75" dia.
I usually arrange my toolpaths so that I leave sufficient material for a last pass carve with the High Core Box Bit
For example in the bottom of a holiday candy dish
Not sure if this is what you are trying to do though!
Just a Thought!!!
Sharkcutup
Just a Thought!!!
Sharkcutup
V-Carve Pro 11.554
V-Carve Pro 11.554
It's a common issue that many people struggle with when moving from a fully 3D product to something like VCarve. I get it all the time with youngsters who are used to doing everything in 3D printing.Ollie wrote: I will give it a go. It is tricky learning a different approach to get a similar result.
What you have to remember is that the shape of the tool is part of the process as well. Totally different results can be achieved from the same vectors by using a round tool, a square tool, a pointed tool or even a form tool. That's where the toolpath preview in VCarve comes into play. You can experiment to your hearts content and see the different results.
Rockler has some nice sign making bits. I have them but not tried them in the CNC yet....
Gary Mitchell
Kentucky, USA
Kentucky, USA
When I need a pocket with filleted bottom corners I typically use an end mill to clear the inside up to the beginning of the fillet, then switch to a ball end bit to do the final pass around the perimeter. When I want to round over the top edge I use roundover bit that is designed for CNC use. No bearing on the roundover bit.
If you want fillets and roudovers that are a radius you can't match with a specific bit, then the moulding toolpath can usually handle those needs.
4D
4D
- Jim_in_PA
- Model of CNC Machine: Camaster Stinger II SR-44 (MacOS user)
Very, very true.Adrian wrote: It's a common issue that many people struggle with when moving from a fully 3D product to something like VCarve.
"Recreating" a 3D design using 2D toolpaths requires one to think in terms of what steps (and cutters) are necessary to accomplish the task. There may also be some requirements to compromise on certain contours. For the stated job to be done, I would probably cut the pocket using large tool clearing and the finish passes with a ball nose. Yes, the "filet" isn't flared with multi-radius like it can be in a true 3D model, but it gets the job done. Rounding over the top edge would be a profile pass "on the vector line" with an appropriate round-over cutter, typically the same radius as the ball nose used for the pocket perimeters. Again, simple, albeit not multi-radius. I will often do the top round-over passes (not one bite for full depth) first before cutting the pockets so there is more material supporting the edge. Note that the round-over cutter must be the "pointed", not bearing type.
If you have any "standard" woodworking experience, think about how you would do it manually with a handheld router, then duplicate that method with the CNC. The toolpaths are nearly the same, but the CNC gets rid of the need for jigs and fixtures to guide the router.
While CAD/CAM programs like other software are great, for the vast majority of woodworking with a CNC, they teach you a lot of bad habits. 3D toolpaths should be avoided at all cost, unless they are the ONLY way to get something done.
If you can stick to 2D toolpaths, you'll get better finishes, and greatly reduced cycle times.
Wow
Thanks for all the overnight responses.
Ger 21-
I do indeed have "standard" woodworking experience, perhaps that is my problem.. ?
I understand what you are saying about trying to stick to a 2d toolpath, part of my problem in this circumstance is the fact I don`t have a suitable cove bit for rounding the top over (all mine have bearings on) and I was going for quite a "mellow" radius at the base of the pockets.
PaulRowntree - I will look on youtube for the gadgets, might be worthwhile paying the difference between desktop and pro.
But also thinking of some other things I want to do in future I would like more shallow bowl cuts larger in diameter than any sensible router bit. So how do I do that?
That is how I was trying to do it at the bottom but also the top.
I watched a couple of youtube clips about the moulding toolpath and I understand the idea but can`t quite get it to work right yet. I will keep trying.
If I can get a satisfactory result and crack the methodoligy of it I will probably shell out for the licence.
Looks like I will need to further expand my already ridiculous router bit collection....
Ollie
Ger 21-
That is what I am trying to do , like the bottom of a candy dish. I have one of those bits kicking around somewhere. I suppose it is all to to with the getting the offset of the tool from the path selected correct ?sharkcutup wrote:When I want rounded edge pockets at the bottom I have used High Core Box Bits .375" dia & .75" dia.
4DThinker wrote:When I need a pocket with filleted bottom corners I typically use an end mill to clear the inside up to the beginning of the fillet, then switch to a ball end bit to do the final pass around the perimeter.
Ollie
- SteveNelson46
Magnate.net has a bowl bit set that may be what you need.
https://www.magnate.net/ProductDetails. ... =RBPBOWL01
- sharkcutup
Above noted Cut Away image is a .25" pocket cut into .5" material with rounded edge bottom and top edge rounded. No OFFSETS involved.That is what I am trying to do , like the bottom of a candy dish. I have one of those bits kicking around somewhere. I suppose it is all to to with the getting the offset of the tool from the path selected correct ?
First Tool path .125" depth Pocketed using a 1/2" dia Straight Bit to removed majority of material.
Second Tool path .125" depth Pocketed using a 3/4" High Core Box Bit
Third Tool path .25" rounded top edge using a Pointed .5" Dia. (.25" radius) RoundOver Bit
Material Setup - 12.0" by 24.0" by 0.5"
Inside OVAL SHAPED bowl measurement - 20.7" by 9.0" carved to .25" deep
Of Course you would use thicker material and two-sided file to carve the opposite side the shape of your bowl but this was a quick n dirty file representation to show
carving of a shallow bowl inside with rounded bottom edges and the top inside edge slightly rounded using tools which I have available to me. No OFFSETS involved!!
The above can be achieved on much deeper pockets too. Just have to make the appropriate necessary changes required.
Hope this helps!
Sharkcutup
V-Carve Pro 11.554
V-Carve Pro 11.554
- highpockets
Using the Moulding Toolpath and Pocket Toolpath to clean up the bottom.
This is most helpful.
Sharkcutup - Thanks for this, it is very helpful indeed. I will try and replicate it myself later. You say no offsets required, last night I was playing with the roundover bits to do the top of the edge.
I found it would only work right if I offset it by the amount of the radius. Do you set up all the bits from the same toolpath or "rail" as I have heard it called.?
highpockets - That is very similar to what I am attempting, am I right in thinking that the small squigly line is the one used for the moulding toolpath, and what bit would you use for this?
I am getting more confident in this software, earlier today I cut out the Bulls head pub sign included in the demo. I used the mach3 post even though I am using UCCNC and it worked fine, I did one in MDF and one in beech. I used a 90 degree V bit 20000rpm 2500mm/min. It was perfect in the MDF but in the beech I had a little burning, just on the ones where it plunges deep straight in (on the deepest parts).
I will be getting one or other version of it this week.
So expect more daft questions soon.
Cheers
Ollie
Cheers
Ollie
