HELP! Need to get LASER pp file to show up in 9.5
- Model of CNC Machine: Shark
- Location: Hamilton, Montana in the beautiful Bitterroot Valley of western MT
I lost battery on old computer. I did copy my CNC data to thumb drive. I need a .pp LASER file imported into my VCarve Pro 9.5 program, but I do not know the correct file folder *Under VCarve Pro 9.5* to cut and paste into. I have it (perhaps foolishly) copied to all listed folders under the File Tree of VCarve Pro 9.5, but it is not showing up when I go in the Tool Selection side of the tool paths. How do I get the laser file to show up so I may use it in a newly created file? Thanks very much. I need to laser some coasters I have created for a graduation party tomorrow afternoon.... (Sunday, June 2).
- SteveNelson46
Re: HELP! Need to get LASER pp file to show up in 9.5
It's usually in:
C:\ProgramData\Vectric\ProgramName\V9.5
You can also select the file menu\"open application data folder"
Steve, Thanks for answering. I have C:\Program Files(X86)\VCarve Pro 9.5\ then the folders showing are: backup, fonts, icons, language, lua, ps, res, win32, x64
and NO file menu in my Search C: or in Search VCarve Pro 9.5, nor do I have a way to open Application Data folder (since I don't see one in 9.5.
Thoughts? thank you so much for your time, Mark
- highpockets
Mark,
You're looking in the wrong place.
The easiest was is as Steve stated, in VCarve, under File->Open Application Data Folder. There will be two folders associated with Post Processors, one called PostP and another called My_PostP
In V Carve Pro, click the File menu, then "Open Application Data Folder". It HAS to be there.
