I just did a "Save Toolpaths to File" Shopbot TC(Inch)(*sbp), and the .sbp file reads as empty.
But when I open it in Notepad, all the text is there.
What causes this and how do I fix it?
Shopbot File Empty Error
- 0.75MDX.crv
- (1.75 MiB) Downloaded 67 times
- 0.75MDX-SHEET1-(#SC15).sbp.txt
- .txt was added for upload purpose.
- (116.87 KiB) Downloaded 81 times
Re: Shopbot File Empty Error
The screenshot you've attached for the ShopBot editor/viewer doesn't have a file loaded as the file name is not displayed in the header.
My first thought was that it probably doesn't like the filename. I can load it into my version ok (2.012) but it depends on what version you have along with which version of Windows I guess. There are lots of annoying bugs with the ShopBot programs. Personally I never use the editor as I don't have a need to. I just load the file and run.
I found that the folder was causing the problem.
I saved the .sbp to the Desktop, which was a good file.
I then copied it to a CNC folder for Shopbot to run, and the file showed empty.
I deleted the CNC folder and made a new one with the same exact name.
I copied the same file from the Desktop to the new CNC folder, and the .sbp now works.
- scottp55
Avoid using any special characters in the file name.... ' apostrophe used to bite me once in a while in the beginning
R.N.
R.N.
