I have a finger joint file from matthew Bishop.
I need to know how to get it into vcarve pro.
I know I have extract the files but from there I have forgotten how to do it
I had this installed on my computer that went bad and had to be replaced.
So i know it works in 9.5
Just for got how to do it
jeff
How to stall a gadget 3d party
Re: How to stall a gadget 3d party
You need to install the files in a new folder in the following location "Public Documents\Vectric Files\Gadgets\VCarve Pro V9.5". On a default Windows 10 install Public Documents is "C:\Users\Public\Public Documents".
- Model of CNC Machine: Shapeoko 3D XXL
Once I have it it the right folder is it supposed to show up in the gadget icon
Jeff
Jeff
Yes, but you need to close and restart VCarve first. If you put the files in a folder of their own then they'll show up as a sub-menu on the Gadgets menu and if they're in the root level then they'll show directly in the Gadgets menu but I wouldn't do it that way unless the gadget only has one file.
If you've created a folder with spaces in it then you might need to replace those with underscores (_) instead. Used to be an issue with spaces in the early days but it might well have been fixed by now.
