First Sign Carve - "V" Bit - Problems
adze_cnc
Re: First Sign Carve - "V" Bit - Problems
Post by adze_cnc »
blackte wrote:I have run several things before without any issues...
Do you have a sample CRV file of something that has run properly in the past as comparison to to this file?
Steven
Leo
Post by Leo »
YEP
You are telling V-Carve that Z zero is top of material
BUT - BUT
You are telling the machine that Z Zero is the machine bed
SOOO - V-carve posts out a program --- THINKING that Z zero is top of material. It drives the tool to zero which is in fact the machine bed. The machine did what it was supposed to do.
You either need to tell the machine that the zero is the top of material OR - select the bottom of material in V-Carve. ONE - or the other.
This is why I was asking you HOW you set zero in your machine.
blackte
Model of CNC Machine: NewCNC Talent T2
Post by blackte »
Yep, just looked at another one that I did, and Machine Bed was checked. I guess I screwed up. Not the first nor will be the last. I was thinking I had seen in one of the tutorial video's if you are carving, you need to set the "Z" to top of material. Once I get my machine re-set, I will try it again to see what happens. Sometimes it's the smallest things to cause you many headaches. I will repost the outcome once I get the file to run again.
Thanks to all for your input.
ger21
Post by ger21 »
If the material thickness varies, it's often better to set Z zero to the top.
But then you would need to set Z zero at the top on your machine, and my guess is that it's not easy to do that, if at all?
Leo
Post by Leo »
Not a problem at all.
Been there done that and WILL most certainly be doing it again and again.
Glad we could help.
BTW - that machine looks like a nice beefy machine.
blackte
Post by blackte »
Leo - yes it is. It is quick and powerful. It will cut just about anything including solid surface material. My main focus is cabinets and doors. I have just started messing around with carving and signage. Trying to add some unique items to my business.
That is one thing I really like about this forum, everyone is very helpful. I belong to other forums and they are not even close to this one. I can spend hours looking through posts just to gain knowledge about what others are doing and the problems they are running into. It's so helpful.
ezurick
Post by ezurick »
Wow! brings back memories... I had that happen to me a couple of times. It was always user error. First time it happened, I zeroed xyz for my material, then loaded in the vcarve .txt to mach3 and hit start and ... blame. Here mach3 decided to CHANGE my xyz to some astronomical number after I loaded in the file and I didn't notice it. I now zero AFTER I load in the file. lol.
That said... if he was getting decent cuts with circles using same settings, why would it be different now? However, I agree that the LENGTH of the tool should be immaterial. I am unfamiliar with his machine, but it does sound like he is not setting the zero to the top of the material properly.
Post by TReischl »
blackte wrote:Here are my settings for this CRV file. To me this is correct. It has the material as 3/4" thick and "Z" is top of material.
No. You said that the machine knows where the surface of the table is at.
Absolutely none of your Z moves should have a negative Z value unless you want to cut into your spoilboard/machine bed.
Here is what your code should look like:
M3
N7 G00 X-13.0397 Y-1.3058
N8 G00 Z1.5000
N9 G00 X-13.0397 Y-1.3058
N10 G00 Z1.1000
N11 G1 X-13.0397 Y-1.3058 Z0.8750 F100.0
N12 G1 X-14.1247 Y-1.3058 Z0.8750 F300.0
N13 G1 X-14.1247 Y-2.3908 Z0.8750
The only way this would not be correct is if you somehow entered material thickness into the machine control.
The above file is based on a part 1 inch thick.
