Circles are too big
Circles are too big
Hi, I have a big problem. I have drawn a part in solidworks, down loaded it to vcarve pro. And used vcarve to write the g code. All this in mm. however when it comes to cutting the circles which should be 22mm did the tool keeps cutting the circle until I stop it at 49mm dia. The driving software is mach3. I have run the g code in a sim and it looks ok. So the fault lays in the way mach3 is reading the g code. Anyone have any answers. Thanks.
Re: Circles are too big
Which post=processor are you selecting when you generate the g-code in vcarve? And what machine are you using? I've accidentally selected the wrong post-processor for my chinese 6040 and it went erratic. Gotta make sure you are selecting the proper one.
- Leo
in v-carve did you select the correct ,,, inside- profile?
- mtylerfl
The difference in size between the circles is about an inch (27mm), so I don’t think that’s his problem.Leo wrote:in v-carve did you select the correct ,,, inside- profile?
Unless he’s using a big ol’ end mill - it’s possible, I guess. (0.5” EM)
Sure do wish folks would upload (or link to) their files. Eliminates a lot of wasted time guessing.
- mtylerfl
Hi Terry,
Check what Leo mentioned. If that’s not the issue, go ahead and post your file here, please. One of us can look at it for you to confirm the whether the Toolpaths are setup properly, etc.
Hi, at the moment this forum locks me out on my pc, so I am using my iPad. So far I have been told the following. Mach3 as a setting called absolute and incremental. The default is absolute but so some reason vcarve is not triggering that setting which is G91.1 I have tried to edit the g code to include the line. But still large circles. I have ran a bit of g code using other software and the circles came out ok. So the fault lays in how mach3 is reading the g code. As soon as I can get on line with the pc I will attach the g code. Thanks for interest.
- Leo
Please upload your VECTRIC file - not the G-Code.
Mach3 reads the g-code exactly as it's written. The most likely scenario is your g-code is wrong.terry1956 wrote:So the fault lays in how mach3 is reading the g code.
terry1956 wrote:Hi, at the moment this forum locks me out on my pc, so I am using my iPad. So far I have been told the following. Mach3 as a setting called absolute and incremental. The default is absolute but so some reason vcarve is not triggering that setting which is G91.1 I have tried to edit the g code to include the line. But still large circles. I have ran a bit of g code using other software and the circles came out ok. So the fault lays in how mach3 is reading the g code. As soon as I can get on line with the pc I will attach the g code. Thanks for interest.
Again, which post-processor are you selecting in vcarve for your machine?
- wmgeorge
He got the information he needed over on the Mach Support Forum, someone looked at his g-code not the VC file.
Posted by Tweakie.cnc Not sure this will cure the problem but....
With Mach3 you must not have the G90 and the G91.1 on the same line of code - they must be on separate lines.
- mtylerfl
Seems odd to me that some folks are reluctant to post their Vectric files here, despite repeated requests.
- wmgeorge
Do the Vectric files include the Post Processor information? Well I just opened some files from 2008 or 2009 done in VCP5.x and no gcode or post processor included. Of course you guys know that. I just wanted to make sure. But I have ran those old files just fine on my new machine and VCP9.5 by selecting the PP for the system I have now.mtylerfl wrote:Seems odd to me that some folks are reluctant to post their Vectric files here, despite repeated requests.
