Machine not returning to work zero
Postby Clockman » Sun Feb 10, 2019 11:26 am
I am using Vcarve desktop and Picsender, I have set up G28 to be my work zero and G28.1 to save it, I also Zero X/Y/Z in Picsender,, so I home the machine then G28 which takes me to work zero, then when the carve is finished it will not return to work zero, it is about 2" off zero in the X direction , it is ok in the Y direction, any help appreciated
Clockman
Model of CNC Machine: Xcarve
Re: Machine not returning to work zero
Postby Adrian » Sun Feb 10, 2019 11:40 am
As far as the VCarve side of things goes the XY home is set in the material setup part of the Toolpaths tab. Does that match with what you're setting the machine to via the G28 etc?
Postby Clockman » Sun Feb 10, 2019 12:41 pm
Thank's Aidrian, yes they do match
Clockman
Return to VCarve - General
Users browsing this forum: Adrian, ger21, kaetamer and 44 guests
