Vcarve and shapeoko, post processor issues
Postby pixelmechanic » Wed Feb 06, 2019 8:50 pm
I'm trying to do an inlay with Vcarve. I've only used VcarvePro for about a month now. I've been using the available shapeoko post processor that came with vcarve. When I make the clearing cut, everything works fine, but when I change to the final cut with the fine bit and reset the Z axis, it always seems to cut twice the depth in the z axis as it should. I've done similar procedures with other software with no issues. I'm wondering if I'm missing something regarding how the post processor is set up? Any help would be appreciated. I searched for post processor issues and it looks like nobody has had any concerns for 3-4 years.
Joel
pixelmechanic
Model of CNC Machine: Shapeoko 3 XXL
Re: Vcarve and shapeoko, post processor issues
Postby Adrian » Thu Feb 07, 2019 9:57 am
The inlay procedure has a toolpath that has a start depth and cut depth so if it's that toolpath you're referring to then it is correct that it cuts deeper than the cut depth as the effective cut depth from the top of the material is the cut depth and start depth added together.
Postby pixelmechanic » Sat Feb 09, 2019 1:11 am
The start depth is always set to 0. I set it for both the detail and using the larger bit for clearing. Whichever cut I do second, whether it be the clearing or the detail, is always deeper.
pixelmechanic
Postby Adrian » Sat Feb 09, 2019 10:56 am
Are you resetting the z-zero correctly between bit changes? Does the Z move to the correct location if you command it via your control software after the first cut? If not you could be losing steps in the first cut.
Postby pixelmechanic » Sat Feb 09, 2019 7:18 pm
I hope so. . .I set it the same way as when I change the bits with the job produced from my other software.
pixelmechanic
Postby Adrian » Sat Feb 09, 2019 8:30 pm
What about the the Z movement? When the toolpath finishes does it return to the same level as when the toolpath started?
I don't see how it can be a post processor issue if it's only affecting one toolpath and not the other. Could you attach the CRV file of the job?
Postby Donnie197 » Tue Dec 10, 2019 11:57 am
I’m having a similar issue.
I’m running Aspire and Carbide Motion with a Shapeoko 3 XXL. My clearing toolpath seems to cut fine. Then I run my 3D finish and it almost cuts thru the board. Carbide Motion also crashes with just over 60% complete. So I reran toolpath using UGS and when it gets to the point where the crash occurred the cut depth is at least .25” shallower.
Any ideas?
Donnie
Donnie197
Model of CNC Machine: Shapeoko 3XXL
Postby wb9tpg » Tue Dec 10, 2019 1:03 pm
Are you using the inch or mm post processor?
wb9tpg
Postby Donnie197 » Tue Dec 10, 2019 2:42 pm
Inch
Here's a pic of what is happening.
Donnie197
Postby wb9tpg » Tue Dec 10, 2019 3:37 pm
I've had an issue with the inch post processor in the past. It looked like the inch PP was generating a very large amount of digits (precision way beyond what was capable) and the Shapeoko would barf on it. I switched to the mm post processor and didn't have any issues with it after that. I never took steps to really diagnose it.
That said I've still had the weird thing occasionally after switching bits and zeroing. I've starting manually entering a G0Z30 command after zeroing to eyeball (yeah, that looks about 30mm) before starting the next tool path. Never had an issue after including that in my workflow.
wb9tpg
Postby Bonch » Tue Dec 10, 2019 3:51 pm
I use the GRBL post processor and have for years. The Shapeoko PP always gave me problems. Never had an issue with the GRBL PP.
Bonch
Postby Donnie197 » Tue Dec 10, 2019 4:02 pm
Thank you
Donnie197
Users browsing this forum: No registered users and 44 guests
