Anyone able to tell me what I could be doing wrong?
Postby mkittle » Tue Feb 05, 2019 5:52 pm
I have had the Piranha for about year and have used it only a hand full of times and this is the first time something didn't come out as expected. I am fairly new to all of this but past projects have worked just fine. On this one, the result doesn't match the preview. I assume I have something set up wrong but don't know enough to know what is wrong. I have tried different depths and different bits and I get the same type of results. I have used a 22 degree and 45 degree MLCS bits from Eagle America (https://www.eagleamerica.com/product...groove_forming). I have attached photos of some of the results and screen shots of the tools I used. I would appreciate any tips or help that anyone can provide.
mkittle
Model of CNC Machine: CNC Piranha
Re: Anyone able to tell me what I could be doing wrong?
Postby adze_cnc » Tue Feb 05, 2019 6:00 pm
Your preview appears to use a 90-degree v-bit. But the two screenshots you show are for 45-degree and 22-deg v-bits.
Seems to me to be a mismatch between what you asked the program to use to create the v-carve (90 degree) versus what you are actually using to cut the job (45 or 22 degree).
adze_cnc
Postby mkittle » Tue Feb 05, 2019 6:02 pm
I also read the post about checking V bit angles and did that test. It didn't seem to work like it should either. I did have to alter the file since my machine can only do 12"x 13" and changed the angles to test the 45 degree bit.
mkittle
Postby mkittle » Tue Feb 05, 2019 6:05 pm
Here is a screen shot from VCarve. I think I have that set to use the 45 degree bit.
mkittle
Postby Leo » Tue Feb 05, 2019 6:05 pm
There are lots of things that could be happening.
1) I don't like using oak for that sort of project. The grain is not really all that strong and it chips out in small and thin areas - I see that in the first pic.
2) It looks like you are just changing the cutter and running the same tool tool path - you cannot do that. You need to program for the tool being used
3) It looks like there is a rigidity issue. Something is loose.
4) Perhaps your cutter is sticking out of the collet too far. DO not clamp ON the flutes, but do get the flutes as close to the collet as possible. Stubby short setup.
If you post the Vectric file - NOT, toolpath, we can look at your settings.
www.leosworkshop.com
Leo
Postby mkittle » Tue Feb 05, 2019 6:13 pm
I am creating a new tool path when I change to try a new bit. I originally wanted to use the 45 degree bit. I tried to upload the file but it is over 3 MB so wouldn't upload. I have it saved in my google drive and have provided the link to it there.
https://drive.google.com/open?id=1xnEd5 ... bbIIE3hYC9
mkittle
Postby mkittle » Tue Feb 05, 2019 6:17 pm
I also switched over to a different project and tried it and it came out as I expected using the same 22 degree bit I tried on this project.
mkittle
Postby mkittle » Tue Feb 05, 2019 6:29 pm
Sorry, I shared that link from the wrong account. Here it is from my personal google drive.
https://drive.google.com/file/d/17zQ_fJ ... sp=sharing
mkittle
Postby Adrian » Tue Feb 05, 2019 6:44 pm
Nothing wrong with the file that I can see. The preview looks as I would expect. The screenshots just look like there is too much movement in the machine and/or it's being pushed too hard with the tool settings you're using.
With the first small machine I had there is no way I could have cut at 100ipm in Oak. I was running at more like 40ipm but I have no idea what your machine is capable of and it probably wouldn't be getting to those speeds anyway on a small piece like that.
Postby Mobius » Tue Feb 05, 2019 7:59 pm
Oak is much harder than the spruce or pine that you used in your Bob Straugh test project. It looks to me like then the bit is cutting deep, it is causing the machine to flex. Then when it becomes shallower you can see how it goes back to where it should. This is evident in your bit angle test.
You need to set up your pass depth on your tools to something less than the full depth of the cutting edge. That way it will make several passes before getting to full depth, and should help your problem in harder woods.
Connor Bredin
www.distinctive-concepts.ca
Mobius
Postby mkittle » Tue Feb 05, 2019 10:10 pm
Thanks for the tips. I will try slowing the feed rate down and decrease the pass depth and see how it turns out.
mkittle
Postby Leo » Wed Feb 06, 2019 12:00 am
Oak is difficult to work with and not just because it is hard. It is brittle and chips out very easily.
I find Maple to be a GREAT wood for this stuff. It is about as hard as oak, but a lot more stable.
Poplar is an OK choice of woods
Cherry is my favorite wood, not quite as stable as Maple, but it is an awesome wood to work with.
For just testing Poplar is relatively inexpensive.
In my opinion the softwoods like pine are not a good choice to test with as it chips out really easy and is just too soft.
Looking at your V-Carve file I see the same thing as Adrian sees. It all looks OK. Saying that - you then need to focus on other things like machine, slides, holders for the spindle, screws and lots of mechanical things. Seems like something is loose
Leo
Postby Bob Reda » Wed Feb 06, 2019 12:07 pm
In the first one you are going against the grain and as Leo said it is getting a lot of chipout. The other you are going with the grain and will get a smoother cut.
Bob Reda
Users browsing this forum: Google [Bot] and 31 guests
