Divide box to 19 equal pars
Postby monlover » Tue Feb 05, 2019 8:58 am
Hi
as you see in the attachment, i want to divide the middle highlighted box on to 19 equal box.
your help is greatly appreciated.
Thank you.
monlover
Model of CNC Machine: Omnitech 4X8 with 8 tool
Re: Divide box to 19 equal pars
Postby mezalick » Tue Feb 05, 2019 9:44 am
Okay, let's see if I can do this...
Here's how I would approach this..
1. Copy / Paste the middle box.
2. Rotate the new box 45 degrees to make it horizontal.
3. Use the " Set Size" tool and in the "width " box add " /19" ,,make sure the "Link XY" box is not checked.
4. Hit "Apply
5. Mirror left ( or right ) 18 times
6. Group new boxes.
7. Rotate - 45 Degrees
8. F9, Center boxes within workspace..
9. Un-Group Boxes
Michael
Michael Mezalick
https://carveddetails.com
mm@mezalick.com
mezalick
Postby monlover » Tue Feb 05, 2019 10:21 am
Brrrrilliant my Friend god blessss.
your help is really and greatly appreciated.
monlover
Postby adze_cnc » Tue Feb 05, 2019 5:51 pm
mezalick wrote:5. Mirror left ( or right ) 18 times
That seems awfully tedious. How about one array copy with no gap?
adze_cnc
Postby mtylerfl » Tue Feb 05, 2019 6:04 pm
Well, you know there are many ways to skin those cats!
Yet another method is select the box and drag while holding the Ctrl key (to make a copy while dragging) and Snap to the previous box. Repeat with multiple boxes selected until 18 copies are done.
I think it was Michael M who coined the phrase, “There are at least three ways to *fill-in-the-blank*.”
Postby mezalick » Tue Feb 05, 2019 6:50 pm
Excellent adze_cnc !! You found one of the three options / alternate ways to do this more efficiently.
My goal in teaching is to push people to think for other, more efficient / effective ways to accomplish the same end results.
So congrats, and lets see if someone else can find the other two alternatives to make it quicker..
Michael
PS, Thanks Michael T
Michael Mezalick
mm@mezalick.com
mezalick
Postby adze_cnc » Tue Feb 05, 2019 7:12 pm
mezalick wrote:So congrats, and lets see if someone else can find the other two alternatives to make it quicker..
Perhaps there are 4 ways? Is:
Mirror 1st box to get 2. Mirror those 2 to get 4. Mirror those 4 to get 8. Mirror those 8 to get 16. Mirror 1 box to get 17. Mirror 2 boxes to get 19.
one of your two alternatives?
Steven
PS. Perhaps, in the interest of teaching rather than just telling, the original step 5 could have been:
5. Your turn: there are at least 3 ways to make 19 boxes from this 1 box
adze_cnc
Postby stanv77 » Tue Feb 05, 2019 7:42 pm
Put one line vertical and one horizontal through your box. Then pick the vertical line hold control and pick horizontal line the cope along a vector 20 times. That will give you 18 lines inside the box. Then delete the 2 lines on either in of the box
It takes longer to explain than it takes to do it. I hope you can understand me explanation
stanv77
Model of CNC Machine: pdj cnc
Postby Adrian » Tue Feb 05, 2019 8:02 pm
There are loads of ways of doing it but a lot depends on whether the boxes need to be boxes or just vertical lines. Without knowing the toolpath to be used the end result it's a drawing rather than machining exercise.
I'd draw a line then copy/paste with a nudge and then use the Space Selection tool to space them out. Advantage of that way is you don't need to bother measuring anything. As with all these things which is the fastest way for each person is down to the tools they use the most. I use those tools many times a day every day so it would take me seconds that way. For someone else it could be tedious.
Users browsing this forum: No registered users and 34 guests
