Hello all,
I just started playing around with the Keyhole Gadget and when I run a simulation on the tool path it just shows an end mill slot. Is there a way to make it look more like a key hole? Am I not using the Gadget correctly?
So I also tried to use the Form Tool in the tool data base to try to make a tool that would cut like a keyhole cutter but can't figure out a single open vector shape of a typical keyhole cutter that the software will accept.
Does anyone have any experience with this?
Thanks, TJ
