Curved surface question..
Postby jaru-eri » Sun Feb 03, 2019 5:07 am
I want to engrave an stl-file on a whale tooth and placed the image on the end of a dome in order to make it fit as good as possible to the curves on the tooth. The problem is that I got an unwanted difference in the z-level as you can see in the attached picture. I want the top level to be more plane, not the curves but the z-level from highest to lowest. Are there any ways to fix this problem?
jaru-eri
Model of CNC Machine: Taig and router, Gecko G540, Mach3
Re: Curved surface question..
Postby Rcnewcomb » Sun Feb 03, 2019 7:27 pm
I'm having trouble understanding what are the troublesome areas, and what do you want the finished item to look like. More images may help.
Postby jaru-eri » Mon Feb 04, 2019 12:41 am
Rcnewcomb wrote:I'm having trouble understanding what are the troublesome areas, and what do you want the finished item to look like. More images may help.
The difference from the highest point to the lowest is very high compared to the same points on the whale tooth. This became so after I placed the STL file on top of the imported clip-art dome, so I'm searching for a solution to lower the highest point to a lower level in order to make it fit the level of the whale tooth.
jaru-eri
Postby Rcnewcomb » Mon Feb 04, 2019 11:31 pm
Are you trying to adjust the shape of the dome to more closely match the whale tooth?
Postby Rcnewcomb » Tue Feb 05, 2019 1:12 am
I think this video may help. The part you are interested in starts at the 7 minute mark: Component Tree Guide
Users browsing this forum: Barry Anderson, dealguy11, Google [Bot], greggph and 13 guests
