Ucnc. To be or not to be?
Postby pal » Sat Jan 26, 2019 5:00 am
Help, my Vcarve V6 has no P.P. for uccnc AM I UP THE CREEK?
pal
Re: Ucnc. To be or not to be?
Postby IslaWW » Sat Jan 26, 2019 5:20 am
Ask your question on the UCCNC forum. Someone there should have one
Gary Campbell
CNC Technology & Training
GCnC411 (at) gmail.com
IslaWW
Postby martin54 » Sat Jan 26, 2019 12:39 pm
There are probably better options but I have used the usbcnc post processor without problem, in fact when I first used it I was sure it said uccnc not usbcnc :oops: :oops:
As Gary says they have a forum so ask there for a better option. :lol: :lol:
Postby ger21 » Sat Jan 26, 2019 12:49 pm
The Mach3 post should work fine.
I'll try to find the time to write a UCCNC post this weekend, and I'll put it on my website.
ger21
Postby pal » Mon Jan 28, 2019 12:54 am
Thank you all for your help. I was a mach3 user running through a UC100. My computer died, the new one has Windows 10 not the old 7 so I am migrating to UCCNC with my old
UC100 together with my old Vcarve Pro V6.
So just hoping there is a compatible P.P. On V6. Thanks. Peter.
pal
Postby pal » Mon Jan 28, 2019 12:57 am
P.s to my last post. I will try the Mach3 Pp as soon as I can get back to my machine. Thanks.
pal
Postby mikeacg » Mon Jan 28, 2019 2:18 pm
Gerry,
Check your URL! It comes up on a search page. Are you at www.thecncwoodworker.com?
Mike
mikeacg
Postby ger21 » Mon Jan 28, 2019 2:26 pm
I have both domains.
cncwoodworker redirects to thecncwoodworker. :)
ger21
Postby Mark's Wood Chips » Mon Jan 28, 2019 5:02 pm
Mach3 PP works perfectly with UCCNC.
Mark's Wood Chips
Model of CNC Machine: ShopSabre 23 with Rotary
Postby ger21 » Mon Jan 28, 2019 5:32 pm
Just be sure to configure UCCNC to Ignore unknown g-codes.
ger21
Postby pal » Fri Feb 01, 2019 11:13 am
Thank you all for your time and responses. Regards. Peter.
pal
Postby ger21 » Fri Feb 01, 2019 12:37 pm
I did throw some UCCNC posts together the other night. I'll get them on my website tonight.
ger21
Postby ger21 » Sun Feb 17, 2019 4:17 am
Two weeks later, I finally uploaded the posts.
http://www.thecncwoodworker.com/uccnc.html
ger21
Postby martin54 » Sun Feb 17, 2019 8:47 pm
ger21 wrote:Two weeks later, I finally uploaded the posts.
OK so I know absolutely nothing about post processors, all I know is that the mach pp, the usbcnc pp & a couple of others all seem to work with UCCNC so how are these you have kindly done different ger21 ? (without getting to technical :lol: :lol: )
Users browsing this forum: Barry Anderson, dealguy11, Google [Bot], greggph, Phil and 13 guests
