Can I move vectors and cut paths at the same time within the work piece?
When I select the vector with the associated cut paths, only the vectors moves.
moving vectors and cut paths
Re: moving vectors and cut paths
Once you've moved the vectors you need to recalculate the toolpaths. You should be able to use the recalculate all button.
Thank you very much, thats exactly what I was looking for!
