Rotary tool path output is wrong.
- Model of CNC Machine: X-carve
I hope someone from vectric.com is seeing this. I'm so excited for the rotary ability. But I found a huge glitch. It is a glitch. I just spent 4 hours digging into it. It's all explained in this video.
https://youtu.be/RtTKuqkpGdM
I can't wait to use my new rotary cnc machine. Just need proper g code.
Re: Rotary tool path output is wrong.
Are you using the correct post processor? there are 2 pp one for wrapping x & one for wrapping y, sounds like you have selected the wrong one
If your rotary is parallel to the X then you need to wrap the Y values. The X movements stay the same. It is the Y movements that need to be translated into rotary movements. Change the post processor to wrap Y.
CorrectRcnewcomb wrote:If your rotary is parallel to the X then you need to wrap the Y values. The X movements stay the same. It is the Y movements that need to be translated into rotary movements. Change the post processor to wrap Y.
What I'm saying is that there IS a glitch that is not allowing you to use the correct post processor.
Along X axis job setup should = wrap Y
Along Y axis job setup should = wrap X
The glitch is it not allowing you to use the correct wrap post processor. If it's not correct, the rotary output box doesn't pop up.
This was a job set up along X. It will currently not pop up this box unless you select a wrap x, which is wrong.
This glitch may be in desktop only.
If you notice also, its saying wrapped around the cylinder 5xx degrees. Which even says that for just a blank cylinder. It should be 360°
Nope. I spent 4 hours on this straight. This is a glitch in vcarve desktop.martin54 wrote:Are you using the correct post processor? there are 2 pp one for wrapping x & one for wrapping y, sounds like you have selected the wrong one
I just tried every single wrap y-axis post processor there was with all the same results. It is not allowing you to use the correct direction rap post processor in V carve desktop 9.5. I will be upgrading to pro and hopefully the glitch is not there.
I am uploading a better video showing exactly the issue or explaining it better. I will post the link when it's Uploaded.
You want to use the Wrap Y values post processor. If you could Zip and upload your rotary post processors that would be helpful
If things are working correctly you should NOT see the Wrapped Output dialog box. That dialog box is a holdover from older versions.
If you want the Y values to be changed to A axis moves then your post processor file should have:
ROTARY_WRAP_Y = "A"
or more likely
ROTARY_WRAP_Y = "-A"
depending on your machine setup. A partial example of machine moves would be"
Likewise if you want the Y moves translated to the B axis you would have
ROTARY_WRAP_Y = "B"
Some people disconnect the Y axis and connect it to the rotary motor because their control box only has support for 3 axes. If this is the case then you would use:
ROTARY_WRAP_Y = "yes"
Example output is:
Notice how the Y moves are all in degrees.
I've always written my own rotary post-processor, but I did look at some that were in the Post P/05 Wrapped folders and frankly, some of those post processors are wrong.
ROTARY_WRAP_Y = "A"
or more likely
Code: Select all
N220 G00 X1.0000 A-36.7606 Z1.2000
N230 G1 X1.0000 A-36.7606 Z0.9000 F120.0
N240 G1 X1.0000 A-323.2394 Z0.9000
N250 G1 X11.0000 A-323.2394 Z0.9000
N260 G1 X11.0000 A-36.7606 Z0.9000
N270 G1 X1.0000 A-36.7606 Z0.9000
N280 G00 X1.0000 A-36.7606 Z1.2000
ROTARY_WRAP_Y = "B"
Example output is:
Code: Select all
N220 G00 X1.0000 Y36.7606 Z1.2000
N230 G1 X1.0000 Y36.7606 Z0.9000 F120.0
N240 G1 X1.0000 Y323.2394 Z0.9000
N250 G1 X11.0000 Y323.2394 Z0.9000
N260 G1 X11.0000 Y36.7606 Z0.9000
N270 G1 X1.0000 Y36.7606 Z0.9000
N280 G00 X1.0000 Y36.7606 Z1.2000
I figured it all out.
- mtylerfl
Did you have to do anything special or was the software correct after all?PhilJohnson wrote:I figured it all out.
In version 9.5 we have introduced direct support for rotary jobs. If correct post-processor is selected in rotary job (i.e. matching the orientation) the "Wrapped Output" dialog is not displayed anymore.
This is intended since the necessary information was provided when setting up the job.
If the orientation of the post-processor does not match that of a rotary job, or when rotary post-processor is selected for single-sided job, "Wrapped Output" will be shown to confirm the user's choice.
Greg K
Greg K
