Hi
I am having a strange thing happen with my roland mdx-540 and vcarve pro.
I am carving a 3D part of a violin arch. I use it for repair patches.
Roughing path works perfectly
First finish path works perfectly
However my final path with a very small .01 tapered bit doesn’t.
The bit drops to the appropriate safe z height and then moves to the correct first cut position, then before it starts cutting the bit moves to the highest z position and begins air cutting the part.
I have tried a dozen different combinations of safe z heights trying to find the glitch.
I am hoping someone may have had this happen or have an idea what’s going on.
Many thanks
John D
Vcarve pro with Roland mdx-540 problems
- Model of CNC Machine: Roland mdx-540, shopsabre
Re: Vcarve pro with Roland mdx-540 problems
Is this 2 different files or have you generated all the toolpaths from the same file? If it's different files then check on the set up where you have set your z zero position, material surface or spoilboard surface
Couple of screenshots of the toolpath set up might help & there are people on here that understand gcode so if you could post the gcode fole then they may be able to tell you whats happening with the code
- mtylerfl
Even better....please post the actual file itself. (Saves a ton of time when troubleshooting questions like this.)
