Hey all Ive got a small machine 17" Im trying to tile a piece so when I moved it to T2 it give me a soft limit alarm g code exceeds machine travel. Dont know what to do. Any ideas? Using desktop.
Tilling longer than my machine
- Model of CNC Machine: bobs e3
Re: Tilling longer than my machine
Can you post your CRV file?
- Model of CNC Machine: Probotix Meteor, Aspire 8.014
Are your tiles 'too big"? As in too long for your machine.
Your x y position doesn't change so the T2 starting position should be exactly the same place as T1, if it's cutting T1 ok then there shouldn't be a problem with T2 as the tile size should be exactly the same. As Randall has said the file might help if this is a software problem but won't if this is actually a machine issue, in that case a couple of pictures might help
