Tapered Surface
Tapered Surface
Postby Ade » Thu Jan 10, 2019 7:23 pm
I am trying to create some pieces that have a slightly tapered surface. They are 24" long and I need the high spot of the taper to be 1" long and then from this point taper down toward each end by .03". Basically, I'm starting with .6875" thick material and I want to maintain that in the middle (for 1 inch) but need it to be .6575 on each end. Can someone point me in the right direction for how to do this in V-Carve or maybe some tutorials that would help with this? Thanks in advance!
Ade
Model of CNC Machine: NewCNC Smart ER Series 2
Re: Tapered Surface
Postby highpockets » Thu Jan 10, 2019 8:03 pm
Look at using the Moulding Toolpath.
In the preview I exaggerated the tape so you could see the results.
A .03" taper over a 11" distance doesn't seem like much.
Hope this helps.
Re: Tapered Surface
Postby adze_cnc » Tue Jan 15, 2019 6:59 pm
I was curious to see how little a 1/32" slope over 11.5" really is. Unlike John I used the fluting toolpath. It's a very minimal slope indeed.
Steven
slope-03in.crv
(89.5 KiB) Downloaded 2 times
adze_cnc
Users browsing this forum: Bret, DanB., KENYPETE and 40 guests
