cutting inside cut
cutting inside cut
Postby Just Starting » Tue Jan 08, 2019 8:50 pm
ha folks
HAPPY NEW YEAR
ok this is whats happening
ive been cutting signs so really didn't notice.
also haven't cut from Thanks Giving till New Year
cnc shark 24x24 table-dewalt router- .25 em bit (sharp)
post processor (cnc shark-USB 3D contour inch)
i cut a circle 2.75 inside cut (building a carriage for a smaller router)
finished cut 2.68-cut a square 3x3 finished 2.95x2.98 also inside cut.
what am i missing here?
thanks
otto
oluhm@bellsouth.net
Just Starting
Model of CNC Machine: CNC Shark v21
Re: cutting inside cut
Postby Rcnewcomb » Tue Jan 08, 2019 10:25 pm
Can you post the file? Oftentimes in these situations the tool diameter in the tool database is different than the tool name, or a different tool was used in the router than was specified in the cut file.
Postby Just Starting » Wed Jan 09, 2019 4:04 am
Sure
I'll get it to ya tomorrow
Otto
Just Starting
Postby FixitMike » Wed Jan 09, 2019 7:40 am
It can be tool and machine deflection. What happens if you run the cut a second time so there is only a slight amount of material removed?
FixitMike
Postby ger21 » Wed Jan 09, 2019 12:36 pm
If you were climb cutting, try conventional.
ger21
Postby Just Starting » Wed Jan 09, 2019 3:04 pm
yep
I did run a second cut.
it ran along the same track
Just Starting
Postby Just Starting » Wed Jan 09, 2019 3:12 pm
router clamp cnc.crv
(223.5 KiB) Downloaded 26 times
here's the file
otto
Just Starting
Postby Adrian » Wed Jan 09, 2019 3:26 pm
Tool sizes look ok. Is the machine properly configured? If you tell it to move one inch does it move exactly one inch etc?
Most likely going to be deflection due to flex in the machine itself or slop somewhere if it's configured correctly. Sharks aren't the most robust of machines so it might be worth slowing the feed rate down.
Postby Just Starting » Wed Jan 09, 2019 3:32 pm
Rcnewcomb wrote:Can you post the file? Oftentimes in these situations the tool diameter in the tool database is different than the tool name, or a different tool was used in the router than was specified in the cut file.
(223.5 KiB) Downloaded 17 times
Just Starting
Postby Just Starting » Wed Jan 09, 2019 3:34 pm
ger21 wrote:If you were climb cutting, try conventional.
i'll give it a shot
thanks
otto
Just Starting
Postby Just Starting » Wed Jan 09, 2019 3:38 pm
Adrian wrote:Tool sizes look ok. Is the machine properly configured? If you tell it to move one inch does it move exactly one inch etc?
that is a great answer. your right about the shark too.
i'll recheck the configureation
thanks
otto
Just Starting
Postby Just Starting » Wed Jan 09, 2019 10:02 pm
adrian
you where absolutely right about robust. i slowed the feed down to 50 then when cutting i slowed it down to 25% and it did great. i was cutting a .75 sheet of clear plexi for a smaller router holder on this machine. you got to pay to play
thanks to everyone for the good advise
otto
Just Starting
Users browsing this forum: No registered users and 38 guests
