cutting a single pass?
Hi guys - I have a dilemma/question, I am running a Vcarve file on a Shopbot CNC and it is not cutting all the way through my material. Is it possible to run a single pass deeper when its done? I have no idea how to program that and it will be a huge PIA to cut these parts out with a jigsaw.
- highpockets
Re: cutting a single pass?
In the toolpath make sure the Cut Depth is equal or more than your material thickness.
- SteveNelson46
Are you setting your Z0 to the spoil board or to the top of your work piece.
If you are profile cutting then yes you can, run another toolpath with the start depth set at the depth you finished cutting & the cut depth to what ever material thickness is left to cut through
so if your material thickness was say 21mm & you had already cut to 20mm bcause you thought that was what the material was then you would make a toolpath with a start depth of 20mm & a cut depth of 1mm or slightly more than 1mm if you wanted to be sure
- Leo
You can CERTAINLY run a final pass at full depth after you run your multiple passes. Simply create another tool path on the same vector but with a full depth pass rather than multiple pass depths. Post both toolpaths as one post and it will happen for you.
thanks everyone I got my answer, I'm still not sure why it didn't cut through. I zeroed correctly, material was flush, and the thickness was .75" and I set the cut depth to .77". This has been a frustration for me, as I don't want to cut into the spoilboard. The vacuum at the shop is missing the downward flashing that keeps it close to the material, and I think because there was a lot of chips on the plywood that may have been part of it.
What extra cut depth do you use? Is .0625" too much?
What would you all recommend as the best bit for cutting .75" hard plywood? I have only used an EM .25" double flute, should I try a compression bit? I like Onsrud.
You said it hasn't cut through all the way, is that the whole piece or has it cut through in some parts but not others? When was the last time you checked your spoilboard, your machine spindle was trammed & the calibration of the machine?
If they are all good then the only other things I can think of to to check are your z zeroing & your collets, have you checked the machine is zeroing to exactly the same spot after the cut? If not then the bit could be slipping in the collet.
I like straight flute bits for plywood, they seem to give me a better edge finish than spirals but I am not an expert, I don't use commpression bits because of the cost, the amount of work I would use them for just doesn't justify the expence but if I were doing more work where they would be of benefit then I would certainly look at buying them
Depending upon the cutter, I will set my depth to z+. 002". For down shear bits I will go deeper but never more than .010". I'm too cheap - at .010" per spoilboard resurfacing I would be replacing my board too often.
My go to bit is a 3/8" compression bit for cabinet parts mostly because I get dozens of sheets out of a single sharpening but I am with Martin, a straight flute often gives me a cleaner cut when sharp at the expense of speed.
- SteveNelson46
Although most 3/4" plywood is marketed as .75 inches, it rarely is. Use a set of accurate calipers to be sure.
To solve the problem of cutting the spoilboard I set my material on top of those rubber spacers used to separate ceramic tiles. They are uniform thickness (about 1/8"), doesn't matter if your cutter hits them as they are soft rubber, are sold by the bag, and are inexpensive!
Cobblewood Carver
The whole idea of a spoilboard is that it gets chewed up over time and is resurfaced when needed though so cutting into it isn't really a problem as such.
- SteveNelson46
I agree with Adrian. IMHO, a spoilboard is just as the name implies. It's sacrificial.
Not that I would want to disagree with Adrian But I don't like cutting into the spoilboard & avoid it by setting my Z0 to the spoilboard when I set up a project in the software as one method or my other method when working off the top of the material is to set my cutter to the spoilboard BUT enter the material thickness as a negative number for my Z height rather than hitting the Z zero button in the control software
Quick edit, I would only use method 2 if I were cutting parts out, for anything else I would set my z zero to the material surface as normal
- Leo
I will cut into sacrificial spacers placed under my workpiece.
I cut pressed hardboard into strips and burn than when they are no longer any good.
One 4x8 sheet of pressed hardboard (masonite) goes a long way when cut into 3" wide by 48" long strips.
I don't really have a spoil board on my machine.
- Model of CNC Machine: Probotix Meteor 25 x 50
I am sorry to say I really don't understand all the fuss about a spoil board. That's what it is . I always check my material with a caliper and set my z height to the material. I've had my machine for 5 years and surface spoil board when needed, second one in 5 years. I am sure not anywhere as good as most on here, but simple should be simple. Check twice , cut once. Have been building cabinets for 45 years, and still do it only , the cnc makes things a lot easier.
Dave
Dave
