could the image i have here be made in to a 3d cut file some way.
Or something like it.
Jeff
3D cut fild
Re: 3D cut fild
When you say 3D cut file do you mean a 3D model the same as the models in the 3D clipart supplied with the software? If so then yes it can be by someone who has the modeling skills to do that, there are people on the forum such as Michael Mezalic who do that sort of thing for a living
If its converting to vectors so you can toolpath it then same again yes it could be redrawn using the tools within the software
- Model of CNC Machine: Shapeoko 3D XXL
Re: 3D cut fild
I have separated The banner from the eyeglasses. And have Vectors for both.
What I want to be able to do is to round over the outer edge and the inner eye of the glasses. Then cut them out.
The banner I want to put some text on it and then pocket out around the text to make the text raised.
Jeff
Jeff
Re: 3D cut fild
You could do that with a roundover bit, which would mean there was no need for a 3D model, the banner & text you already know how to do
- adze_cnc
Re: 3D cut fild
...and if round-over bits are not the same diameter as what you are trying to achieve you could use the moulding toolpath to accomplish this and still not need a 3D model.martin54 wrote:You could do that with a roundover bit, which would mean there was no need for a 3D model
Re: 3D cut fild
I am not familiar with how the moulding tool works.
Jeff
Jeff
- sharkcutup
Re: 3D cut fild
V-Carve Pro 12.004
V-Carve Pro 12.004
