Help with this picture
SB61
Model of CNC Machine: Dave Gotten Plans
Post by SB61 »
My wife found this picture on Pinterest and wants me to make her one.
Could any one help on how I can get this in a vectors so I can cut it out. I would leave the center blank, she does not want a letter in the center.
Thanks if anyone can help.
SB
garylmast
Re: Help with this picture
Post by garylmast »
Imported in has a bitmap and use the trace bitmap. If it's a low resolution picture, the trace may not come out well so do some node editing my hitting "N". Sometimes it easy to edit on side and cutoff the other side, then mirror (Under transform Objects).
For the best results I wouldn't use the trace bitmap as it's such a simple shape (plus it's a poor image) and you only need one side of it. Import the bitmap and use the drawing tools on top of it.
Have a look at the Tracing Images videos here - http://support.vectric.com/tips-and-tricks/select.php
Post by martin54 »
+1 for what Adrian has suggested, if you want to be able to use the software properly then you really should learn how to use the drawing tools. This would be a good project to start, with it being an organic shape then it only needs to be roughly the same. No pressure to get every curve exactly the same as the image you are tracing, as long as it looks much the same when you have finished all will be good.
The more you pracice with the drawing tools the quicker you will get :lol: :lol: :lol:
meflick
Post by meflick »
Another option would be to do a google search for a basic silhouette of the same shape. You can even do a search for a vector image silhouette, I bet you should find some fairly easily.
meflick
Post by meflick »
meflick wrote:Another option would be to do a google search for a basic silhouette of the same shape. You can even do a search for a vector image silhouette, I bet you should find some fairly easily.
I just did and a large number of silhouette images came up.
Paul Stewart
Model of CNC Machine: Scratch Built
Post by Paul Stewart »
Something like this
V-Carve 8.5 file
Cutout preview file
User node editing to trace .
Crab.crv
(1.91 MiB) Downloaded 112 times
Post by martin54 »
The forum is great with lots of very helpful people, it was very good of Paul to do it & upload the file BUT that won't help you to learn how to use the software yourself :lol: :lol: :lol:
SB61
Post by SB61 »
Thank to all......Thank you Paul!
Ton80
Model of CNC Machine: Shapeoko 3XXL / Carvewright RevB
Post by Ton80 »
I agree... it can be intimidating and maybe even a bit frustrating at times but there is nothing like working out something with the tools for yourself!. There will be projects where you are just going to have to know how to edit something and the only way to understand what you need to do is get in there and attack some images using the drawing tools.
