Adding fonts
- Model of CNC Machine: Stoney CNC
Adding fonts
Can anyone please advise me how to go about adding different fonts to Vcarve? Thanks
Re: Adding fonts
Help > Help Contents then search for: fonts
Re: Adding fonts
FAQ: How to Add Fonts
How can I add more fonts?
Additional True Type and Open Type fonts (.TTF) can be obtained from many sources and available to use once the font has been properly installed the Windows Font Directory and the program restarted.
This is not hard to do and typically if you right click on the font file, it will give you the option to install the font. If that option is not available, the exact process can be found in the Help Document for your version of Windows.
The included Single Line Fonts are installed during the program's installation and cannot be changed or added to.
