3 watt laser
3 watt laser
How far should the laser be offset from the material?
- Model of CNC Machine: eBay special China 3040
Re: 3 watt laser
Cheap Chinese laser rig? You should be able to focus the beam at low power. Just get the smallest dot you can get.
- BArnold
- Model of CNC Machine: SO2/XCarve hybrid w/NEMA23 on all axes
Re: 3 watt laser
The instructions for you laser should provide that information.
Example: I recently set up a J-Tech 2.8W unit on my CNC. Its instructions say it should achieve proper focus between 1.25" and 3" from the surface of the material. I currently have mine set at about 1.5" and adjusted the focus to provide the smallest dot. It works great!
Bill Arnold
VCarvePro, PhotoVCarve, SketchUp, UGS
Member of Mensa and NRA
- meflick
- Model of CNC Machine: Shark HD4
Re: 3 watt laser
Did you get the one they have to go with your shark? I have that one (got it free last year when we purchased the machine as I recall.) but haven't tried it yet. I did track down the manual/information for it I believe from the Shark forum/website. Let me have a look and see if I can find it and share a link back for you.clajpen wrote:How far should the laser be offset from the material?
Found it here: http://nextwaveautomation.com/downloads ... _Guide.pdf
Re: 3 watt laser
I wonder if what is being asked is not the focus distance for cutting but rather the amount of allowance for kerf to make sure pieces are the "right size". If the latter that depends on your power and speed settings on a per job basis. You'll need to do a test first then use that knowledge to set the appropriate values as needed.clajpen wrote:How far should the laser be offset from the material?
