Hello All,
Is there a way to space the letters in a word if they are to close to engrave ?
Thanks in advance !
Brian
Text spacing ..........
- Model of CNC Machine: Tormach PCNC II/III
- Model of CNC Machine: Shapeoko 3 XL
Re: Text spacing ..........
For script fonts like Edwardian, I first "Convert to Curves" and move the letters around, Weld, then node edit to blend the letters together.toolznthings wrote:Hello All,
Thanks in advance !
Brian
Gary Mitchell
Kentucky, USA
Kentucky, USA
If you're using a vcarve toolpath you can use the Text Spacing tool and keep it as text as that toolpath handles overlapping script fonts. Makes it a lot easier to edit etc if it stays as text.wb9tpg wrote:For script fonts like Edwardian, I first "Convert to Curves" and move the letters around, Weld, then node edit to blend the letters together.toolznthings wrote:Hello All,
Thanks in advance !
Brian
