Set toolpath Cut Depth from imported vectors
Postby Jacala » Fri Nov 09, 2018 4:13 pm
Like a famous sister once said "what does this button do?"
" Set toolpath Cut Depth from imported vectors" in the vector selection menu when assigning a tool path is mentioned once in the manual on page 233.
I have been trying to figure out this option: I guess to get a proper layer name to assign a cut depth to a certain vector? Maybe I am overseeing something but I can not find out what it does and how it works. It sounds interesting but is it?
Thanks in advance for the golden tip.
Jacala
Model of CNC Machine: 2040 atc with 12 tools
Re: Set toolpath Cut Depth from imported vectors
Postby ger21 » Fri Nov 09, 2018 6:21 pm
If you use a CAD program that can draw vectors at Z levels other than Z = zero, the depth of cut will be at the Z level the vectors are located at.
Gerry
ger21
Postby Jacala » Mon Nov 12, 2018 7:53 am
Hello Ger!
Thanks for pointing that out to me. It will check if I can use this function.
Jacala
Users browsing this forum: phill05 and 41 guests
