Code question
Code question
Postby JohnsCNC » Tue Nov 06, 2018 11:34 pm
Can anyone tell me what this line of code does?
N140G00G43Z0.8000H1
It seems that after I set the z height with the auto button, this code seems to change the z height to .8 without moving the machine and when the program continues to run, it too high.
JohnsCNC
Model of CNC Machine: Homemade CNC
Re: Code question
Postby rscrawford » Wed Nov 07, 2018 12:21 am
Did you calibrate your tool length measuring switch? Usually, that line of code would set the tool offset using a number (in this case 0.8) that corresponds to the offset of the switch from your spoilboard. So if your TLMS is 0.8" above the level of your spoilboard, then this offset would set your tool height to the exact level of your spoilboard. Calibrating the TLMS to the current spoilboard height should give you an exact measurement with your auto tool measures.
Russell Crawford
rscrawford
Model of CNC Machine: CAMaster Cobra 408 ATC with recoil
Re: Code question
Postby ger21 » Wed Nov 07, 2018 1:18 am
It applies a Tool Length offset using the length in your tooltable, for tool #1, and moves it to Z0.8.
The typical format for G43 would be G43H1 Z0.8
If you do not have an ATC, or fixed length tooling, you generally do not want to use G43 tool length offsets.
Gerry
ger21
Re: Code question
Postby JohnsCNC » Mon Nov 12, 2018 12:20 am
Thanks for the help. No tool offsets, yet.
JohnsCNC
Users browsing this forum: IslaWW, sjwiehe and 41 guests
