Carving multiple identical items ??
Postby medic7392 » Mon Nov 05, 2018 2:04 am
Is there a way to set up on v carve pro so I can carve the same item multiple times on the same sheet of wood?
medic7392
Model of CNC Machine: X Carve
Re: Carving multiple identical items ??
Postby mtylerfl » Mon Nov 05, 2018 2:55 am
Yes. Just copy/paste then position the copy (or copies) or drag the model while holding the Cntrl key down to make a new copy.
Postby scottp55 » Mon Nov 05, 2018 4:06 am
Linear array and nesting?
scottp55
Postby mtylerfl » Mon Nov 05, 2018 4:28 am
Yes! That too! (and Level Mirror)
Postby scottp55 » Mon Nov 05, 2018 4:30 am
Have fun on your trip Michael! :)
scottp55
Postby mtylerfl » Mon Nov 05, 2018 4:33 am
Thank you, Scott!
Postby Adrian » Mon Nov 05, 2018 9:32 am
In addition to the previous suggestions (personally I use nesting with automatic toolpaths) you can also use the Array Copy Toolpath.
Postby Rcnewcomb » Mon Nov 05, 2018 4:50 pm
Also, depending on your control software, you can do it at the machine level where you offset to a new location, which is treated as the new home position, and run the job again.
Postby potzmannwoodshop » Mon Nov 05, 2018 5:56 pm
Rcnewcomb wrote:Also, depending on your control software, you can do it at the machine level where you offset to a new location, which is treated as the new home position, and run the job again.
I have this, I can set a temporary origin, or home position, and call another program from within the g-code running on my machine. This is in the machine software. This is a great feature IMHO, it allows me to quickly change order batching for clients.
potzmannwoodshop
Model of CNC Machine: 2 SCM Routech Record 120s(1999, 2001)
Users browsing this forum: Google [Bot], mark-s and 36 guests
