inkscape file acting funny
Postby hack613 » Tue Oct 30, 2018 2:20 am
So I made this atom shape in inkscape.
I then unioned it all together so it looks like an atom.
When I load it into v-carve it looks all out of shape.
Any idea what's going on?
hack613
Model of CNC Machine: Various 6040, 3020, 2020
Re: inkscape file acting funny
Postby highpockets » Tue Oct 30, 2018 3:53 am
What does it look like when you take the STL back into Inkscape?
Postby LittleGreyMan » Tue Oct 30, 2018 7:48 am
Hello,
Which file format did you use to export the drawing from Inkscape?
Can you post the Inkscape file and the exported file?
John, you probably meant the vectors exported from Vcarve, not a STL?
Best regards
Didier
W7 - Aspire 8.517
LittleGreyMan
Postby gregk » Tue Oct 30, 2018 9:25 am
Hi hack613,
It may be an import issue - please send the .svg file to support@vectric.com and we will have a look.
Greg K
gregk
Model of CNC Machine: None
Postby Bob Reda » Tue Oct 30, 2018 9:31 am
It might have something to do with all the crossing vectors.
Bob Reda
Postby hack613 » Tue Oct 30, 2018 11:42 am
Thanks everybody!
Here's the file...
I'm just opening it up directly by dragging and dropping the file on the vectric icon...
hack613
Another try, I didn't notice but I think it didn't like my svg file. I just zipped it.
atom001.zip
(59.22 KiB) Downloaded 44 times
hack613
Postby kilrabit » Tue Oct 30, 2018 12:11 pm
Try exporting as an .eps, from inkscape.
kilrabit
Postby Adrian » Tue Oct 30, 2018 12:24 pm
Definitely an SVG import issue. Converting to another format imports fine. I used Xara in this case but Inkscape can do it as well.
atom001.eps
(16.36 KiB) Downloaded 45 times
Postby LittleGreyMan » Tue Oct 30, 2018 1:41 pm
Adrian wrote:Definitely an SVG import issue. Converting to another format imports fine. I used Xara in this case but Inkscape can do it as well.
+1
Same result with Affinity Designer
Best regards
Didier
W7 - Aspire 8.517
LittleGreyMan
Postby hack613 » Tue Oct 30, 2018 2:02 pm
Thanks for all the help!
I opened the SVG file in inkscape, then did saveAs to a PDF. Now it works perfectly.
So that allows me to move forward.
I also sent the file to support as they said they might tweak the import process so the svg behaves (assuming that's where the issue is).
Funny, I used to always export to a pdf and one day I noticed that the SKP (sketchup) and inkscape files can be dropped directly on my vectric icon. That's been working perfectly except this anomaly.
For the record, when I said "inkscape file acting funny', I didn't mean humorous. Bahahaha....
hack613
Postby gregk » Wed Oct 31, 2018 5:29 pm
It seems we got to the bottom of it. It was a quite peculiar mismatch in the conversion between the coordinates systems. Should be fixed in the next patch.
The issue only affects SVG files containing elliptical arcs. Sorry for the inconvenience.
Greg K
gregk
Return to VCarve - General
Users browsing this forum: FixitMike and 41 guests
