How to enlarge and reduce the size of the job in the display area with the keyboard?
Not change the size of the job, just the visual display.
VCarve pro 9.5
Re: VCarve pro 9.5
The shortcut keys are on the Help menu.
You can't zoom in and out using the keyboard in the same way as you can with the mouse. The only option you have that is 100% keyboard controlled as far as I know is Ctrl-F and F which would zoom to the size of the job or material.
Everything else requires some form of mouse interaction such as selecting vectors etc.
Re: VCarve pro 9.5
If your mouse has a center wheel, roll that back and forth to zoom in and out.
