Maybe I just can not figure this out it seems simple but it needs to be real accurate. So, some help would certainly be appreciated for sure.
Ok, here goes
Would like to draw a series of line at specific angles all starting from the same point. I.E. board say 6" wide by 12" tall starting point to connect all the line at the lower left corner one inch above the board edge. At these degrees: 5, 10, 15, 20, 25, 30, 35, 40, 45, 50
I know how to draw a line and use the "Rotate Selected Objects Tool" tool to rotate each line but can not figure out how to anchor all of them to the same point in the lower left hand corner.
So, what am I messing.
Thanks for any help you can provide.
Angled Lines starting from the same point
Re: Angled Lines starting from the same point
If this feature is available in Vcarve, use "Create a circular array of copies" in the "Offset and Layout" button group.
Best regards
Didier
W7 - Aspire 8.517
Didier
W7 - Aspire 8.517
It is. VCarve has all the 2D tools that Aspire has.
- Model of CNC Machine: Laguna CNC
Thanks so much works like a charm. Much appreciated
