Rotary text on curve
- Model of CNC Machine: Shapeoko
I have a new Camaster with a rotary axis running parallel to the Y axis. How would I design text in Vcarve Pro to follow an angle on the Y axis? Foe example; a baseball bat that is mounted in the rotary and I want to vcarve text both directions. If I do conventional wrapping the text would be deeper on the bottom than the top. If I was carving the entire bat I could project the text onto the model but I am using a commercial bat. Same with the text following the Y axis; it would continue to get shallower the farther up the Y axis it travels? Any hints or videos would be appreciated.
- IslaWW
Re: Rotary text on curve
Terry...
If I understand you correctly you will need to make a 3D model of the bat, or have someone make one for you, then setup your VCarve as you wish and then "project toolpath onto 3D model"
Gary Campbell
GCnC Control
GCnC411 (at) gmail.com
GCnC Control
I was afraid that might be the case. I am actually doing sides of Beads of Courage bowls but I thought the bat example would be easier to explain. I don't believe there is a way to do the 3D work in V-Carve Pro so it may have to wait until I upgrade to Aspire. In the meantime I may be able to adapt something from a Design & Make model.
Thanks for your help.
- wmgeorge
You have a rotary correct and you said Camaster. Why can't that be used to do what you want? Our laser guys engrave text all the time on mugs and wine glasses. I have only used my VCP 9.5 to do pre made 3D like from Design and Make but you can also Import 3D files, I think STL, perhaps from other software. I am on the MacBook Pro and can not access my VCP.
https://www.vectric.com/products/vcarve.htm
But then again, can't you simply change either X or Y to your rotary axis? That is to say that if the bat is oriented along Y then you change X axis to input into the rotary axis so the rotary drive moves to simulate X. Unless you have a variable or compound radius? That way you don't even have to wrap; the setup behaves like a flat surface. In that case I would define the X Y origin in the center of the project work area.
Thanks to everyone for their suggestions. I will try to setup a model in a CAD package.
